On the hunt
09-24-2018, (Subject: On the hunt )
On the hunt
Just found this on the floor board underneath my pedal ..pulling the cover off now anyone have a clue what it might of came from
./uploads/201809/post_3494_1537822680_206f08d6cf3dffaf014da7b08fa0cfc0.jpg
RE: On the hunt
Steering column tilt mechanism?????????
RE: On the hunt
Clutch pedal..found the other piece of it..
RE: On the hunt
Clutch pedal return spring
RE: On the hunt
Not sure what's its called,there a rod that connects to the clutch pedal in hold in with a cutter pin.this truck has a hydraulic clutch so not sure if that make a difference..
