Governor Type
12-02-2018, (Subject: Governor Type )
Governor Type
Can anyone explain the differences between the 2 governor types in features/parameters
I have
Automotive
And
Variable Speed
my truck was Automotive but i set to Variable speed to see if there's any change this week to how the engine acts.
ive tried some searching and only found a saying in truckers report that variable speed is like driving a mechanical cat..as ive only driven a 3406E i dont really know the difference except in the golden days of yesteryear a mechanical engine would just throw more fuel the more you pushed the pedal compared to computer control
thanks for any input!
12-03-2018, (Subject: Governor Type )
RE: Governor Type
Automotive varies the torque depending on throttle position...50% tps=50% torque.
Variable speed means that at 50% tps=50% governed rpm and it will apply 100% torque to keep it there or get it to that rpm.
RE: Governor Type
ic i did notice in my lower 4 gears my but o meter thought i could actualy move instead of feeling like im pulling a steel brick with no wheels behind me.
