INSITE / INLINE Compatibility
05-02-2016, (Subject: INSITE / INLINE Compatibility )
Hi, today I've been having issues with INLINE 6 and INSITE 7.5
The computer in question is using 7.5 so that I can keep the current PC date, and 7.5 does everything I need it to. Just as I connect to an ECM, INSITE crashes. I've got the latest INLINE drivers & firmware and the adapter is genuine and known to be working. Aside from trying a fresh install of INSITE I'm not sure what else to try. Any ideas anyone?
08-22-2016, (Subject: INSITE / INLINE Compatibility )
RE: INSITE / INLINE Compatibility
What differences between inline 5vs6?
08-23-2016, (Subject: INSITE / INLINE Compatibility )
There is a patch available so you don't have to mess with the date but you need to get it from a different site.
Rawze don't allow software swapping. Good luck.
On my truck the copper pegs from ecm plug were corroded from water and needed to be replaced. It would work for a few seconds but cut out and give fault code.
I worked the problem out and I'm using 7.6 now. I forgot to update the thread when I fixed it.
