| cummins cm2350 code 1141 |
| 01-30-2019, (Subject: cummins cm2350 code 1141 ) Post: #1 | |||
| cummins cm2350 code 1141 I have one truck a 2015 prostar. About once a year after an complete engine service the trucks next trip gets a 1141. The code comes and goes the next morning when i check it the code is inactive and does not have a miss. The driver complains on his trip the light comes on and off. I dont believe its actually the injector any one have any ideas. | |||
| 01-30-2019, (Subject: cummins cm2350 code 1141 ) Post: #2 | |||
| RE: cummins cm2350 code 1141 Is there any injector circuit codes? If not it probably is a malfunctioning injector. If it is repeatable you could move it to a different hole and see if the problem follows. | |||
| 01-30-2019, (Subject: cummins cm2350 code 1141 ) Post: #3 | |||
| RE: cummins cm2350 code 1141 See attachment from Cummins QuickServ. | |||
| 02-01-2019, (Subject: cummins cm2350 code 1141 ) Post: #4 | |||
| RE: cummins cm2350 code 1141 No circuit code the code no longer goes active but after a service it will activate to inactivate for a couple days then stay off for good. | |||
