Cleaning dpf with water??
02-12-2019, (Subject: Cleaning dpf with water?? )
There's a guy on YouTube that's washing out dpf's with a pressure washer. This actually work?
{VIDEO REMOVED}
RE: Cleaning dpf with water??
No it does not. One should tell the guy in that video that he should fix what is causing the filter to plug up in the first place!
 Thanks given by: dhirocz , LargeCar
(02-12-2019 )tree98 Wrote:  There's a guy on YouTube that's washing out dpf's with a pressure washer. This actually work?
{VIDEO REMOVED}
Yeah, I had watch that also ....I think best is to have it baked (300 bucks? is cheap) ......that being said? in a pinch? I would probably try it?
this has been discussed in detail, do a search and you will find it. It washes the metals away and makes the filters useless.
User's Signature: 52 41 57 5a 45 20 53 4d 45 4c 4c 53
 Thanks given by: dhirocz , DSTdriver , Waterloo
02-13-2019, (Subject: Cleaning dpf with water?? )
NEVER USEA LIQUID ON YOUR DOC/DPF--- BAD VIDEO!!!!!!!
http://rawze.com/forums/showthread.php?t...6#pid32406
02-08-2020, (Subject: Cleaning dpf with water?? )
{link removed by Rawze}
I’ve heard of these machines being the latest method. I guess time will tell.
That's water,that's a big no no! Scroll up this page a little and you'll see I asked about using water.
(02-08-2020 )Magard Wrote:  {link removed by Rawze}
Now those are some serious idiots.
Believe it or not when I worked at a small stealership, Cummins would wash them out with some type of solution but this was 7 or 8 years ago. After I found that out the Co. quit sending them over there. How I discovered this was I would always blow shop air thru the filter with a blow gun and a crap load of clear liquid would came out the back. I have no idea if they still do this like I said it has been a long time ago.
