Glider Engine....? |
02-22-2019, (Subject: Glider Engine....? ) Post: #1 | |||
Glider Engine....? so i ordered another glider, it will be built in a few months. Question i have and my internal debate is, CAT c16 or a custom built signature 600, 870, or 871, non vgt? I'm planning on having either one set to 750ish hp. I've had a C16 and loved it but its not the best on fuel.....BUT nothing is the best on fuel hauling cattle, or hauling hay stacked to 13.6 on a flat bed. Performance and reliability are more important to me than fuel mileage. What is all of your opinion? Can a well built isx out perform a C16 reliably? would i be better off sticking with the C16? | |||
02-22-2019, (Subject: Glider Engine....? ) Post: #2 | |||
RE: Glider Engine....? First question.. Why non vgt? | |||
02-22-2019, (Subject: Glider Engine....? ) Post: #3 | |||
RE: Glider Engine....? | |||
02-22-2019, (Subject: Glider Engine....? ) Post: #4 | |||
RE: Glider Engine....? I just spent a year driving a c16 set at 600hp .....to compare it to a 2018 isx15 at 565hp? the isx would pull down to 1400rpm cat 1500rpm ...jake was way better on isx and the cat had retarder along with jake .....the c16 I drove was better on fuel than an acert c15 we had by far ....not sure how it compared to millage on isx I only drove it once in awhile. C16 was probably more reliable and I only say this as the isx was new and ended up back in shop several times for different issues .....haha! yeah they put on a new turbo ... I seen somewhere that you can get 1000hp out of c16 with stock parts ....I would lean to the c16 ....but then I have always liked cat engines. | |||
02-22-2019, (Subject: Glider Engine....? ) Post: #5 | |||
RE: Glider Engine....? (02-22-2019 )suicidejockey Wrote: so i ordered another glider, it will be built in a few months. Question i have and my internal debate is, CAT c16 or a custom built signature 600, 870, or 871, non vgt? I'm planning on having either one set to 750ish hp. I've had a C16 and loved it but its not the best on fuel.....BUT nothing is the best on fuel hauling cattle, or hauling hay stacked to 13.6 on a flat bed. Performance and reliability are more important to me than fuel mileage. instead of butchering the isX into a garbage dump,.. use the C16 so you can abuse the hell out of it, brag about your "yellow motor" like a true super-trucker, and waste fuel like a fool... Enjoy the view--- BECAUSE YOUR FUNDING these guys .... ![]() User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
