Finally installed my bypass filter
05-14-2016, (Subject: Finally installed my bypass filter )
Initial start seems ok-no leaks. I really would like a ball valve where the pressure comes out, but it would have been so heavy. The line for this filter is a lot bigger than what was used for my big gulf coast filter on my last truck.
I'll probably be stopping every 5 miles to check it for the next 6 months.
./uploads/201605/post_1778_1463256095_904dc7ea6441696bf784490a63de0d3a.jpeg
RE: Finally installed my bypass filter
./uploads/201605/post_1778_1463256501_159b4bbe186a33e1146d6340ac3e05fd.jpeg
./uploads/201605/post_1778_1463256633_a08ed421e28aa2a767b47d0d0b4d27f5.jpeg
./uploads/201605/post_1778_1463257054_8d10f677297d989f7fe288322d37602a.jpeg
I attached it to my hose rack.
Looks pretty good.
05-16-2016, (Subject: Finally installed my bypass filter )
Good job, Did it too,Buț went The shorter route right there By The oil supply
In my custom oil hose shop those long Lines would be more than 250$
(05-16-2016 )T680 Wrote:  Good job, Did it too,Buț went The shorter route right there By The oil supply
I hear you. I would have liked to but couldn't seem to jam it in anywhere sensible. And with side fairings I couldn't put it halfway, rear of the steps.
05-19-2016, (Subject: Finally installed my bypass filter )
It looks good bud.
06-13-2016, (Subject: Finally installed my bypass filter )
What do you figure your into that?
