Fuel rail pressure
05-04-2019, (Subject: Fuel rail pressure )
Fuel rail pressure
Fuel rail pressure fault... I have a 2012 t660 with a Isx ,and at first 5 miles of my day , the truck stumbles .. looses power for a second then runs fine ...but after that runs great... what should I check ?
RE: Fuel rail pressure
Throwing any codes? Have you checked the fuel pump? Has the fuel pump had any maintenance? How many miles on the truck?
 Thanks given by: Magard
05-05-2019, (Subject: Fuel rail pressure )
If its throwing fuel rail pressure faults or any fuel related faults on a cm2250 which is what im guessing you have being 2012. replace/rebuild the pump immediately. the fuel pumps in the 2250 and 2350s can an will destroy the entire engine if they let loose
from what ive seen posting around here a common rebuild mileage is 350-400k miles to reduce the risk of a 30-40k boat anchor.
