Pre-emission ISX turbo issue
05-15-2019, (Subject: Pre-emission ISX turbo issue )
RE: Pre-emission ISX turbo issue
Silly question what was it boosting before the turbo change? If they put the same turbo on it shoulda been boosting the same.
You mentioned you replaced the vacuum line to the turbo did you also replace the air box controlling the air too? Maybe it's not letting enough air through. Causing the gate too open later
 Thanks given by: hhow55
05-16-2019, (Subject: Pre-emission ISX turbo issue )
It was boosting 35 to 38 before
All was changed..
06-09-2019, (Subject: Pre-emission ISX turbo issue )
Anymore insight to my turbo issue?
max boost on a cm570 should be 20
