| gear oil at oil change |
| 06-01-2019, (Subject: gear oil at oil change ) Post: #1 | |||
| gear oil at oil change hey guys i know this topic might have been beat to death already, but i cant seem to find any info in past topics so i ll start a new one. what type of gear oil do u guys use for cm871 when u say to put a gallon in at oil change? just wanna try it see if itll actually make a noticeable difference on my engine. 09 isx cm 871 demandated. Thanks | |||
| 06-02-2019, (Subject: gear oil at oil change ) Post: #2 | |||
| RE: gear oil at oil change I use Supertech brand 80w90. | |||
| 06-02-2019, (Subject: gear oil at oil change ) Post: #3 | |||
| RE: gear oil at oil change I used supertech 75-140 my last oil change on my cm871 User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 06-02-2019, (Subject: gear oil at oil change ) Post: #4 | |||
| RE: gear oil at oil change I’ve been using the Supertech 80/90 too. $12 and some change at Walmart is hard to beat. | |||
| 06-02-2019, (Subject: gear oil at oil change ) Post: #5 | |||
| RE: gear oil at oil change CRC Sta-Lube 24239 Multi-Purpose Gear Oil 85W90 SAE-Gallon, 128. Fluid_Ounces https://www.amazon.com/gp/product/B000M8...UTF8&psc=1 | |||
| 06-02-2019, (Subject: gear oil at oil change ) Post: #6 | |||
| RE: gear oil at oil change Sta lube has I believe better additives than Wal-Mart brand. | |||
| 06-02-2019, (Subject: gear oil at oil change ) Post: #7 | |||
| RE: gear oil at oil change The one thing I know about Sta Lube, is that the classic car guys swear by the stuff due to the additive package, especially the zinc and Molly. Is it better than what Walmart sells? For our application, I would say either is fine. Me, I stick with the Sta Lube, as I have seen the inside of my motor, it works, you could smell it when the front gear cover came off, the gears had a nice coating of the Sta Lube on them. | |||
| 06-03-2019, (Subject: gear oil at oil change ) Post: #8 | |||
| RE: gear oil at oil change Thanks guys | |||
| 06-03-2019, (Subject: gear oil at oil change ) Post: #9 | |||
| RE: gear oil at oil change Is there a ratio that you guys are using of gear oil to overall oil capacity? I've got a smaller engine, so 1 gallon would be about 1/4 of my total oil capacity, which doesn't seem like a good idea at that ratio. | |||
