New egr cooler failure rate |
06-24-2019, (Subject: New egr cooler failure rate ) Post: #1 | |||
New egr cooler failure rate I think I remember reading here somewhere that the egr cooler failure rate is high on new engines. I think it was just the original cooler that would fail at such a high rate.Anyone know where that was? | |||
06-24-2019, (Subject: New egr cooler failure rate ) Post: #2 | |||
RE: New egr cooler failure rate I think you're correct. The OEM expects them to fail within the 1st 75k miles due to the block settling. I don't know where the article is though. | |||
06-24-2019, (Subject: New egr cooler failure rate ) Post: #3 | |||
RE: New egr cooler failure rate that was for the 871's back in the day. not sure if it is still a problem as they changed the mounting design. I know internally the OE ones are tough as nails though these days. i think you were referring to this thread ref: http://rawze.com/forums/showthread.php?t...2#pid20682 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
06-24-2019, (Subject: New egr cooler failure rate ) Post: #4 | |||
RE: New egr cooler failure rate That's the one thanks Rawze | |||
