Parts pricing mayhem. |
07-17-2019, (Subject: Parts pricing mayhem. ) Post: #1 | |||
Parts pricing mayhem. Had the top break off one of my air cleaners today so i priced out new ones. The single air cleaner frame is $650 for that part or you can buy the kit for $550 that is picture. No sense at all User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
07-18-2019, (Subject: Parts pricing mayhem. ) Post: #2 | |||
RE: Parts pricing mayhem. Back about 2000 I needed track rod bushings for my Pete. At the dealer they wanted something like $95 per bushing and I then would have had to change them out. Or I could buy the whole track rod with bushings already installed for $180. Makes no sense that I could ever come up with. User's Signature: Too young to quit........Too old to change. | |||
07-18-2019, (Subject: Parts pricing mayhem. ) Post: #3 | |||
RE: Parts pricing mayhem. Tie rod ends are like that a lot of the time. Buy the whole tube with 2 new tie rod ends for barely more then 1 end costs. And you dont have to get both ends unfrozen. | |||
07-18-2019, (Subject: Parts pricing mayhem. ) Post: #4 | |||
RE: Parts pricing mayhem. Single speed Horton fan hub assemblies are minimum $2,500. You can overhaul them with a super duty kit for $6-800 in parts and all you reuse is the pulley and the stub/shaft that bolts to the engine. | |||
07-18-2019, (Subject: Parts pricing mayhem. ) Post: #5 | |||
RE: Parts pricing mayhem. (07-18-2019 )Signature620 Wrote: Single speed Horton fan hub assemblies are minimum $2,500. You can overhaul them with a super duty kit for $6-800 in parts and all you reuse is the pulley and the stub/shaft that bolts to the engine. i agree i rebuild a ton of these what horton charges is crazy for what the actual cost of doing it is. | |||
07-18-2019, (Subject: Parts pricing mayhem. ) Post: #6 | |||
RE: Parts pricing mayhem. I'm about to put a bearing kit into my kysor hub. At 1 million miles I consider it preventative maintenance. If I get the whole hub from international it's a little over $1000...the bearings from Napa...$97...go figure. | |||
07-19-2019, (Subject: Parts pricing mayhem. ) Post: #7 | |||
RE: Parts pricing mayhem. Nilao, be careful with the heavy duty spring in the hub. There is a cage tool for them and they are a strong one. | |||
07-19-2019, (Subject: Parts pricing mayhem. ) Post: #8 | |||
RE: Parts pricing mayhem. Not the hub the fan mounts to, the hub the clutch assembly mounts to that has the pulley. It is only 2 bearing held in with clips. The are pressed in with an arbor press. | |||
07-19-2019, (Subject: Parts pricing mayhem. ) Post: #9 | |||
RE: Parts pricing mayhem. Yeah got my new best fit radiator installed 680 bucks also came with the 8 slide pin bushings and the 4 slide pins. International wanted 2000 for the rad and $35 per bushing and idk what for pins. Only problem with new rad was all the 2ndary ports for trans cooler/pitcock/hose to plastic tank we're about 1 inch off so had to cut some peices out of radiator cage frame by pitcock and hose to tank. Didn't care about trans cooler ports as I had an air cooler installed instead User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
