| Metering actuator question... |
| 10-17-2019, (Subject: Metering actuator question... ) Post: #1 | |||
| Metering actuator question... Putting the truck together, and noticed the metering actuator window, that little plastic bubble is cracked and it looked like a bit of fuel had dripped out of it. Is this something that I have to replace or what? I searched all over quick serve, nothing about this window/bubble being damaged. Advice please. | |||
| 10-17-2019, (Subject: Metering actuator question... ) Post: #2 | |||
| RE: Metering actuator question... You got a pic Waterloo? I don't have an answer but I'm also not sure what your referring to. | |||
| 10-17-2019, (Subject: Metering actuator question... ) Post: #3 | |||
| RE: Metering actuator question... It's the clear price on actuators facing you when hoods open bout a half in round clear price that tends to look like it has an air bubble in it. User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 10-17-2019, (Subject: Metering actuator question... ) Post: #4 | |||
| RE: Metering actuator question... This on an 870 or just 871 ? | |||
| 10-17-2019, (Subject: Metering actuator question... ) Post: #5 | |||
| RE: Metering actuator question... 870 871 both use same actuators but loo has 871 User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 10-17-2019, (Subject: Metering actuator question... ) Post: #6 | |||
| RE: Metering actuator question... Yep, that wax cover, one has a tiny nick in it, just wondering if this is anything to be concerned with. | |||
| 10-17-2019, (Subject: Metering actuator question... ) Post: #7 | |||
| RE: Metering actuator question... I tend to believe eventually, it would begin to suck air into fuel system. User's Signature: It's hard to win an argument with a smart person, but it's damn near impossible to win an argument with a stupid person | |||
| 10-17-2019, (Subject: Metering actuator question... ) Post: #8 | |||
| RE: Metering actuator question... If this is a possible issue down the line, the knick is very small, anything to patch it with? Maybe liquid electrical tape? Or something like a gel superglue? Gorilla tape? LOL | |||
| 10-17-2019, (Subject: Metering actuator question... ) Post: #9 | |||
| RE: Metering actuator question... unless it is leaking fuel, I would not worry about it. Maybe put a touch of silicone in it to keep dirt out of it. It is just a dust cover for the coil, does not seal anything normally. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
