|  Volvo/N14 hp  |
|  11-21-2019, (Subject: Volvo/N14 hp )  Post: #1 | |||
| Volvo/N14 hp  Can HP be turned up via insite? 2000 volvo 660 with N14?  | |||
|  11-21-2019, (Subject: Volvo/N14 hp )  Post: #2 | |||
| RE: Volvo/N14 hp  Nope.....  | |||
|  11-21-2019, (Subject: Volvo/N14 hp )  Post: #3 | |||
| RE: Volvo/N14 hp  So its gotta be done via Volvo software?  | |||
|  11-21-2019, (Subject: Volvo/N14 hp )  Post: #4 | |||
| RE: Volvo/N14 hp  No, it has to be done with a cummins program called c@lterm. Don't ask where to get it, you'll have to find out for yourself. But even if you had it, you can't just backspace the 400 hp and type in 600hp. It's way way WAY more complicated than that. If your looking to have something like that done you should PM unilevers.  | |||
|  11-21-2019, (Subject: Volvo/N14 hp )  Post: #5 | |||
| RE: Volvo/N14 hp  Yes it can with insite, but just like the ISX and others it depends on the CPL and what the rest of the drivetrain can handle.  | |||
|  11-21-2019, (Subject: Volvo/N14 hp )  Post: #6 | |||
| RE: Volvo/N14 hp | |||
|  11-21-2019, (Subject: Volvo/N14 hp )  Post: #7 | |||
| RE: Volvo/N14 hp  Insite can be used as long as a factory program of slightly higher HP is avail in that same tier engine/cpl + the programs are checked by someone and deemed to be 100% compatable. A person is not likely to find say, a 600hp program for a 400hp engine using Insite, but bumping one up a little bit is very easily done in many cases using insite alone. Some related info... http://rawze.com/forums/showthread.php?tid=1 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  11-23-2019, (Subject: Volvo/N14 hp )  Post: #8 | |||
| RE: Volvo/N14 hp  I want to bump it from 430 up to 500 which I believe it can be done without changing anything other than programming  | |||
