2011 kw t660 leaning on passenger side??
12-15-2019, (Subject: 2011 kw t660 leaning on passenger side?? )
I noticed a couple months ago my truck was leaning a good 2" lower on passenger side than drivers side. I checked the springs for cracks, replaced shocks, steer tires, alignment and still the same. I also changed sleeper air bags, shocks 1 month ago. I cant really see the cab bushings that well they are tucked really good under passenger seat area. Any thoughts? It's starting to bug me now.
RE: 2011 kw t660 leaning on passenger side??
Is it the body leaning or the frame?
I only measured the body. From floor to hood on top of tire. No accidents ant 736k I'll measure the frame today
 Thanks given by: Mattman
How about some pics?
Right side steer leaf springs could be worn causing a lean due to engine torque twisting the body towards it.
 Thanks given by: Brock
8-bag? The "KW lean"
Pete's do it too. They seem to be using cheaper and cheaper materials. My pass side was 1.25" lower, driver side measured correctly. I ended up putting two new springs on and re-shimmed. Like mentioned above, find a good level slab and get to measuring.
I'll take some pics and post
As said already, its the passenger leaf spring.
Do I just replace with new oem spring or get a stiffer spring?
