| Fuel pump question |
| 02-12-2020, (Subject: Fuel pump question ) Post: #1 | |||
| Fuel pump question Any help is appreciated.. I have a 2011 isx15 2250 Pete and I noticed oil leaking from under the fuel pump. What does that mean? I know dumb question but I’m new to OO aNd trying to figure out what’s going on | |||
| 02-12-2020, (Subject: Fuel pump question ) Post: #2 | |||
| RE: Fuel pump question Post a picture so we can see what you see. The oil pressure sensor is located (behind) under the ifsm, could be a bad oring on that sensor leaking oil. | |||
| 02-12-2020, (Subject: Fuel pump question ) Post: #3 | |||
RE: Fuel pump question ![]() ![]() It’s leaking right under the fuel pump .. and second pic is my head of the pump it has 8 bolts instead of 4 like everyone else’s | |||
| 02-12-2020, (Subject: Fuel pump question ) Post: #4 | |||
| RE: Fuel pump question [attachment=6236][attachment=6235] It’s leaking right under the fuel pump .. and second pic is my head of the pump it has 8 bolts instead of 4 like everyone else’s | |||
| 02-12-2020, (Subject: Fuel pump question ) Post: #5 | |||
| RE: Fuel pump question The fuel pump mounting gasket is leaking but it could also have a leaking gear housing gasket. | |||
| 02-12-2020, (Subject: Fuel pump question ) Post: #6 | |||
| RE: Fuel pump question Recently did my gear pump, it was leaking at a point that was not serviceable, had to replace the pump, wasn’t too bad. | |||
| 02-12-2020, (Subject: Fuel pump question ) Post: #7 | |||
| RE: Fuel pump question Ok thanks for the info I’m thinking about just replacing the pump a new is going to cost me 900 bucks to update to a two plunger system.. or 600 bucks for a reman pump.. | |||
| 02-12-2020, (Subject: Fuel pump question ) Post: #8 | |||
| RE: Fuel pump question You are saying you can get a new two piston pump for $900?? User's Signature: 2015 Kenworth T660 | |||
| 02-12-2020, (Subject: Fuel pump question ) Post: #9 | |||
RE: Fuel pump question (02-12-2020 )Mattman Wrote: You are saying you can get a new two piston pump for $900?? does not sound quite right to me either. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
