10spd to 13spd(ATTN DRIVELINE GURUS)
02-17-2020, (Subject: 10spd to 13spd(ATTN DRIVELINE GURUS) )
My volvo needs a new clutch...previous owner had ecm bumped up to 500hp...truck has eaton/fuller 10spd....I would like to swap in a 13...found one local but it's only 1450 torque...I have 1650 with the 10spd now. Will the 1450 13spd hold up or am I asking for problems? Thanks in advance.
Rears are 3.58...11r 22.5 rubber. Pulling dry van 40~50k loads.
RE: 10spd to 13spd(ATTN DRIVELINE GURUS)
As i understand the difference in the 14913 and the 18913 is cooling which can easily be upgraded. Id call a tranny shop and ask em if theres any bearing, gear or case differences in the exact model u have and a rtlo18913 or u can use the eaton website and compare the part#s. Also make damn sure u send that drive shaft to a reputable driveline shop to have it shortened balanced and tested. I have a dead truck in the yard because my reputable guy wasnt real great after all.
I haven't seen my trans above 175 since disconnecting it from the radiator and putting on an air cooler from my Kenworth dealer used to always be 200+
User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s - skateboarder
 Thanks given by: smorgan87
(02-17-2020 )Lonestar10 Wrote:  I haven't seen my trans above 175 since disconnecting it from the radiator and putting on an air cooler from my Kenworth dealer used to always be 200+
I dunno why they call em coolers. Them coolant to oil exchangers are more like tranny heaters. Worthless and a disaster waiting to happen. The more places oil and water meet the more chances of a problem imo. I personally wish the engine oil could be air cooled effectively.
 Thanks given by: Mattman
the engine oil temps need to stay (200+ degree range) a bit above the coolant temps to keep moisture driven off.
03-08-2020, (Subject: 10spd to 13spd(ATTN DRIVELINE GURUS) )
The 1450 will do fine. You just need to be smooth with take offs. These guys are right about trans temp. That’s what will kill a transmission, well and snatching gears.
03-09-2020, (Subject: 10spd to 13spd(ATTN DRIVELINE GURUS) )
Well I decided to play it safe and upgraded further with a 1850 torque 18 speed...should have no problems...
Air cooled here on my 18spd, rarely if ever goes above 175*, running standard gear oil in her.
(03-09-2020 )Daytripper Wrote:  Well I decided to play it safe and upgraded further with a 1850 torque 18 speed...should have no problems...
Good choice. That should handle over 2k ftlbs without any problems
