oil sampleresults
03-15-2020, (Subject: oil sampleresults )
oil sampleresults
oil sample
Can I get some feed back on my results. It is an cm 870, with egr valve still on and working , 500hp, 13 spd, 3.73 rears. Mileage 865000.
RE: oil sampleresults
./uploads/202003/post_4443_1584299547_6c554dd0ee7eed823d13b0400e190de4.jpg
Looks good to me, what exactly are you looking for?
just to make sure everything looks good , no high levels of anything due my oil change every 10,000 by pass oil filter has been on for 3 months. Thanks for looking!!
(03-15-2020 )Neighbor Wrote:  oil sample
16k miles with 11 on the iron is decent. That rotella has 1100 zinc and that is good too.
However though... if you have 800k miles on it then it is well due for new rod and main bearings. -- You need to do this now and not wait any longer. - Doing this will ensure the bottom end (wrist pins especially) holds up well into the 1.3+ million mile range, and not doing it now ( recommended at 800k) will become a curse later on that will haunt you ias the engine makes it past a million.
It's impressive you made it this long with a functioning egr system on an 870.
Appears to be tested by Horizon Labs. Same one I use, but through a different company. I have nothing bad to say about them. They are usually pretty quick and provide plenty of information. Although, I haven't used any others to compare with.
User's Signature: "The sky above the port was the color of television, tuned to a dead channel."
