Air conditioning issues 2015 ProStar
04-23-2020, (Subject: Air conditioning issues 2015 ProStar )
Got a 2015 ProStar that blows cold air when idleing but blows hot air when going down the road. Also can’t seem to locate the thermisters on the truck.
RE: Air conditioning issues 2015 ProStar
POSTED BY RAWZE -
04-19-2020, (Subject: A/C Cooling Issue ) Post: #24
RE: A/C Cooling Issue
The truck makers, they know the A/C systems are going to be a money maker for them. They are designed to do nothing but act up and run like a P.O.S. all the time. - They are designed to be nothing but problematic in these newer trucks.
-- I got totally sick of it a long time ago on my own truck and solved it.
I no longer suffer Air conditioning issues. I solved all of my trucks A/C problems with an Arduino ... Works like a charm.
Here is some more info related to the A/C and a link to that arduino project that I did as well ... http://rawze.com/forums/showthread.php?t...7#pid14467
Thanks but I don’t know what an arduino is
(04-23-2020 )Kritter47 Wrote:  Thanks but I don’t know what an arduino is
it's a little circuit board you can program commands into using a C++ program.
replacing the thermisters is likely the fix.
post an overview pic of the passenger side of your truck up by the firewall where the big black plastic A/C box is. That is where the thermisters will likely be.
here are where mine are located...
./uploads/202004/post_2_1587685860_b31dea579d5eeecfcef177fdd0a5a904.png
A person needs to bleed the system to zero before attempting to remove them.
Im prty sure thermisters were eliminated on the 15s
(04-23-2020 )smorgan87 Wrote:  Im prty sure thermisters were eliminated on the 15s
i thoguht they were just sealed up and covered over with heat shrink tubing on the newer ones ... but i may be wrong.
(why i requested a couple pics of what they actually have).
04-24-2020, (Subject: Air conditioning issues 2015 ProStar )
Id send some pics but my truck aint here. Driver should have it this way next week to rpl the compressor and filter dryer.
