CM870, injector going bad? Maybe? |
07-17-2020, (Subject: CM870, injector going bad? Maybe? ) Post: #1 | |||
CM870, injector going bad? Maybe? Back again folks! With my Frankenstein cm870 build :p. So I thought I had algae issue in my tank but I think the fppf killem did it’s job, now my davco is looking like it’s got oil in it.... A mechanic told me it’s probably the injector or injector cup or a sleeve? I replaced all of the injectors when I was rebuilding to motor, i reused the head at that time of the rebuild. What are the chances of the head going out on me?. Fml.... I just got back to work after 4 months of nothing but dirt cheap freight. I don’t need this right about now. I replaced my carrier bearing last week and now this.... it never stops man, one thing after another lol. User's Signature: The creator said " Help your self and I will help you; Protect your self and I will protect you " | |||
07-17-2020, (Subject: CM870, injector going bad? Maybe? ) Post: #2 | |||
RE: CM870, injector going bad? Maybe? Send a fuel sample to the lab and find out exactly what it is instead of guessing. Maybe it isn't even oil User's Signature: Warranty??? Yeah right, I am the warranty!!! | |||
07-17-2020, (Subject: CM870, injector going bad? Maybe? ) Post: #3 | |||
RE: CM870, injector going bad? Maybe? (07-17-2020 )tree98 Wrote: Send a fuel sample to the lab and find out exactly what it is instead of guessing. Maybe it isn't even oil You think getting a sample from one from both tanks and then one from the davco would be smart? User's Signature: The creator said " Help your self and I will help you; Protect your self and I will protect you " | |||
07-17-2020, (Subject: CM870, injector going bad? Maybe? ) Post: #4 | |||
RE: CM870, injector going bad? Maybe? Just grab one sample from the davco, that should do just fine. User's Signature: Warranty??? Yeah right, I am the warranty!!! | |||
07-18-2020, (Subject: CM870, injector going bad? Maybe? ) Post: #5 | |||
RE: CM870, injector going bad? Maybe? Go to quickserve, and checkout "sympton search". User's Signature: It's hard to win an argument with a smart person, but it's damn near impossible to win an argument with a stupid person | |||
07-18-2020, (Subject: CM870, injector going bad? Maybe? ) Post: #6 | |||
RE: CM870, injector going bad? Maybe? definitely send a sample out. Its waaaay cheaper to find out you got some funky fuel or something got tossed in the tanks accidentally than to replace engine parts then find that out. | |||
