| Advice for new isx cm871 owner |
| 08-31-2020, (Subject: Advice for new isx cm871 owner ) Post: #1 | |||
| Advice for new isx cm871 owner I just bought my first isx truck. It’s an 2010 kenworth cm871 pre def motor. I have been researching and learning as much as I can about these engines on this forum and through rawze’s videos. Does any have any suggestions as far as what should be done to an engine like this with no service history. I was wanting to start with the egr cleaning videos. Just looking for other suggestions as well or upgrades/ updates people recommend. Thanks in advance and this forum is amazing. No bull just good people helping, it’s definitely a great resource! | |||
| 08-31-2020, (Subject: Advice for new isx cm871 owner ) Post: #2 | |||
| RE: Advice for new isx cm871 owner How many miles? Gearing? Transmission and rear ends? EGR Tuneup BIG YES. Do that first... Any issues or codes, and is it deleted? User's Signature: 2008 ProStar, OEM 600hp CM-871, 18spd, 3:42, in framed in Rawze's driveway. Every day is a fresh new episode of, "The Twilight Zone"... Rod Serling lives rent free in my head. I can smell the Chesterfields. | |||
| 08-31-2020, (Subject: Advice for new isx cm871 owner ) Post: #3 | |||
| RE: Advice for new isx cm871 owner maybe start by reading, researching, etc... here is a decent place to start... http://rawze.com/forums/showthread.php?t...1#pid31741 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 08-31-2020, (Subject: Advice for new isx cm871 owner ) Post: #4 | |||
RE: Advice for new isx cm871 owner (08-31-2020 )Waterloo Wrote: How many miles? Gearing? Transmission and rear ends? EGR Tuneup BIG YES. Do that first... Any issues or codes, and is it deleted? It’s a dump truck so a little different specs than most of you guys run but it’s 364k miles, 8ll trans with 4.10 gears. One code of outside air temp sensor but so far nothing else. It’s not deleted or mandate’d yet. | |||
| 08-31-2020, (Subject: Advice for new isx cm871 owner ) Post: #5 | |||
| RE: Advice for new isx cm871 owner You will need one of these... https://www.ebay.com/itm/Cummins-INLINE-...SwIJlZ9U~7 User's Signature: 2008 ProStar, OEM 600hp CM-871, 18spd, 3:42, in framed in Rawze's driveway. Every day is a fresh new episode of, "The Twilight Zone"... Rod Serling lives rent free in my head. I can smell the Chesterfields. | |||
| 08-31-2020, (Subject: Advice for new isx cm871 owner ) Post: #6 | |||
RE: Advice for new isx cm871 owner (08-31-2020 )Rawze Wrote: maybe start by reading, researching, etc... here is a decent place to start... Thanks!! I really appreciate all the time and effort you put into this. It’s amazing the amount of info here. | |||
