TC (traction Control light on) |
09-10-2020, (Subject: TC (traction Control light on) ) Post: #1 | |||
TC (traction Control light on) Hello every one, I have 2016 KW T680 and the TC (traction control) light is on all the time; the switch do not work to turn it off. If any one can point me how to troubleshooting this and turn this light off will very appreciate. Thank you. | |||
09-10-2020, (Subject: TC (traction Control light on) ) Post: #2 | |||
RE: TC (traction Control light on) You've got a abs code disabling the system. You need bendix software or Google how to pull the blink codes for your model truck. | |||
09-10-2020, (Subject: TC (traction Control light on) ) Post: #3 | |||
RE: TC (traction Control light on) | |||
11-20-2020, (Subject: TC (traction Control light on) ) Post: #4 | |||
RE: TC (traction Control light on) did it come on after a CECU update? | |||
01-30-2021, (Subject: TC (traction Control light on) ) Post: #5 | |||
RE: TC (traction Control light on) I'm going to join on this thread. I have a 2014 T680. Yesterday I had it demandated and today I used Paccar ESA to disable the DEF gauge and its blinking red light. In the process I had to update my CECU and Instrument cluster. It gave me several MIL lights which I cleared with Insite but my Traction Control light is now on. I'm guessing I need to update the TC module now? | |||
01-30-2021, (Subject: TC (traction Control light on) ) Post: #6 | |||
RE: TC (traction Control light on) After some further research I found that when updating the CECU it automatically enables Traction Controls and Stability Control. My truck does have TC but not Stability Control (to my knowledge) so I disabled that and it the light went away. Hopefully it stays that way when I drive it! | |||
01-30-2021, (Subject: TC (traction Control light on) ) Post: #7 | |||
RE: TC (traction Control light on) (01-30-2021 )Golfnut Wrote: After some further research I found that when updating the CECU it automatically enables Traction Controls and Stability Control. My truck does have TC but not Stability Control (to my knowledge) so I disabled that and it the light went away. Hopefully it stays that way when I drive it! thanks for sharing. Maybe this helps someone else that has the same issue. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
01-31-2021, (Subject: TC (traction Control light on) ) Post: #8 | |||
RE: TC (traction Control light on) What truck was that on? Have a Mack does anyone know if it is possible to disable stability control on a Mack truck? In Canada in the bush roads causing issues when it starts braking when need speed for the next hill | |||
01-31-2021, (Subject: TC (traction Control light on) ) Post: #9 | |||
RE: TC (traction Control light on) Mine was a 2014 KW T680. | |||
