Oil pressure issue.
10-10-2020, (Subject: Oil pressure issue. )
RE: Oil pressure issue.
If it plugs up again, you are probably looking at broken piston rings.
If you want to keep it going for a while, use an LF9070.
 Thanks given by: Rawze , Waterloo , redbeard
how long has it been MM2ed could be from engine running so much cleaner a bunch of carbon buildup in oil galleys and everywhere else finally cleaned up enough or sludged up enough in oil pan that you go a slug of it shot into the filter.
