| 2250 Dreaded Fuel PUMP |
| 10-16-2020, (Subject: 2250 Dreaded Fuel PUMP ) Post: #1 | |||
| 2250 Dreaded Fuel PUMP Looking for some Ideas - ISX 2250 the common 0559 Fuel Pump issue - Truck at idle would suddenly almost die completely and pick back up would occur every 6-7 Seconds Ended up replaced entire Fuel Pump as Cam was eat up/etc - Complete new Pump had to change 2 fuel lines as is new design etc. Once complete an idle no codes truck ran great , Test drive when accelerate it falls on its face and dies... Once again the dreaded 0559 Fuel Rail Pressure Mod / severe low ........ Not finding any leaks..... Ideas? | |||
| 10-16-2020, (Subject: 2250 Dreaded Fuel PUMP ) Post: #2 | |||
| RE: 2250 Dreaded Fuel PUMP will it pass a fuel rail pressure test? Did anyone check the front gear train and drop a main bearing to see how extensive the damage from the pump was? -- If not then for all you know, the new pump may be eaten up from all the metal shaving running around in the engine that the last pump left behind. just the thoughts that run thru my head any ways. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 10-16-2020, (Subject: 2250 Dreaded Fuel PUMP ) Post: #3 | |||
| RE: 2250 Dreaded Fuel PUMP Tried to Run Fuel PSI Test - and his clutch switch has failed so not letting me run test until i get switch to replace.... Unfortunately this truck has not been maintained. | |||
| 10-16-2020, (Subject: 2250 Dreaded Fuel PUMP ) Post: #4 | |||
| RE: 2250 Dreaded Fuel PUMP Clutch switch in and failed Levels out does not stay as steady as most i have seen fluctuates 28500 to 29700 psi Drop off 9000 then 10000 psi in 60 seconds Guess next step is by the book Fuel Pressure Test they are fun lol | |||
| 10-16-2020, (Subject: 2250 Dreaded Fuel PUMP ) Post: #5 | |||
| RE: 2250 Dreaded Fuel PUMP Not maintained so probably sent trash into injectors and regulator User's Signature: 2010 Lonestar - CM871 - 13sp - 3.70s, 2016 T680 - cm2350 - 13sp - 3.36s - skateboarder | |||
| 10-18-2020, (Subject: 2250 Dreaded Fuel PUMP ) Post: #6 | |||
| RE: 2250 Dreaded Fuel PUMP How far back does the fuel pump issue go? Is it 2250 only? | |||
| 10-18-2020, (Subject: 2250 Dreaded Fuel PUMP ) Post: #7 | |||
RE: 2250 Dreaded Fuel PUMP (10-18-2020 )DVT873 Wrote: How far back does the fuel pump issue go? Is it 2250 only? 2250 was the introduction of the high pressure systems with the pump. 2250 forward, and it is still an issue. User's Signature: 2008 ProStar, OEM 600hp CM-871, 18spd, 3:42, in framed in Rawze's driveway. Every day is a fresh new episode of, "The Twilight Zone"... Rod Serling lives rent free in my head. I can smell the Chesterfields. | |||
| 10-18-2020, (Subject: 2250 Dreaded Fuel PUMP ) Post: #8 | |||
RE: 2250 Dreaded Fuel PUMP (10-18-2020 )DVT873 Wrote: How far back does the fuel pump issue go? Is it 2250 only? Started with the switch to the high pressure common rail in the 2250, includes 2350 and most likely the current X15. As far as I understand it's all the same pump design, just the X15 isolates the oil circuit so when it fails it doesn't take out the rest of the engine. OP: You're obviously working to find the source of the pressure loss, no real suggestions beyond the troubleshooting you're already working on. But beyond that, you (or the customer) need to consider the extended damage from the metal in the oil. Besides the fuel pump you have the oil cooler which can get plugged up. The overhead cam and rockers. The main bearings. Piston cooling nozzles. All the oil passages through the head/block, rods, etc... Also inspect the front gears as that's were the contaminated oil goes first. User's Signature: "...And as we wind on down the road, Our Shadows taller than our Soul..." | |||
| 10-18-2020, (Subject: 2250 Dreaded Fuel PUMP ) Post: #9 | |||
| RE: 2250 Dreaded Fuel PUMP How did cummins go about isolating the oil for the x15? Why doesnt the filter catch the shrapnel in the 22-2350 engines? | |||
