SAS fault
10-18-2020, (Subject: SAS fault )
SAS fault
I have a 2012 Pete 587 and I purchased an aftermarket steering wheel and hub kit as my factory steering wheel covering was completely falling apart. I replaced the steering wheel and now have a SAS (steering angle sensor) fault. Is there a process to reset this or will I have to find someone with a computer and software?
10-19-2020, (Subject: SAS fault )
RE: SAS fault
(10-18-2020 )kellyedrew Wrote:  I have a 2012 Pete 587 and I purchased an aftermarket steering wheel and hub kit as my factory steering wheel covering was completely falling apart. I replaced the steering wheel and now have a SAS (steering angle sensor) fault. Is there a process to reset this or will I have to find someone with a computer and software?
Need computer and software to recalibrate sensor. If truck with Bendix ABS/TCS you can use ACom diagnostic from Bendix and Inline adapter.
