turbo leaking oil
02-26-2016, (Subject: turbo leaking oil )
turbo leaking oil
pulled my turbo off cm 871 had oil in tube to air charge cooler once removed found oil also in exhaust pipe but no oil in exhaust manifold. I figured seals gone, turbo shop says turbo cant leak both sides, i must have bad head or something. anybody ever seen them leak both sides?
RE: turbo leaking oil
it can certainly leak both side's. find a new turbo shop.
User's Signature: 52 41 57 5a 45 20 53 4d 45 4c 4c 53
thanks, well its under warranty and their going to replace seals in it but i have a feeling hes going to wash it down and reassemble.
i cant think off any way to check if he does or not
My 1st and only turbo failure had oil shooting out both ends.
(02-26-2016 )slowpoke Wrote:  thanks, well its under warranty and their going to replace seals in it but i have a feeling hes going to wash it down and reassemble.
mark it with a scribe or scratches, paint pen that would show if disassembled.
Like Uni said, find a new turbo shop.
90% of the non cummins remans out there for vgt's are junk. honestly the only reliable one ive seen so far has been dr. ISX's guy - most last only days
he did split it open in-front of me but not the turbines core section where seals are. i'm picking it back up tomorrow at noon if i invert turbo pore oil in drain port and let sit would oil seep past seal normally? only thing i can think of
It would probably need pressure and heat.
okay i wont bother then thanks
