Popping like sound
03-12-2016, (Subject: Popping like sound )
Post: #19
RE: Popping like sound
(03-12-2016 )Rawze Wrote:
(03-11-2016 )Coco620 Wrote:  ..
they claim everything looks good suggested I just run it
If Unilevers has heard it, and it is back-feeding into the intake, even a minor leak will eventually wash out a liner and take out a cylinder. It could also cause cavitation elsewhere. For anyone to blindly say "ruin it like that" has to be a complete idiot! in my opinion!.
Rawze is blowin fire again!!!! Good to hear.
./uploads/201603/post_1845_1457785835_4294e3ddfef7c51216e5e082be1b8b50.jpg
Post: #20
Lmao!!! I totally agree ! Unilevers is The man! I think that was a way of saying we don't have a clue what that is.
Post: #21
Love it!! He's back!!
Post: #22
It's for sure intake valve? I wonder if jake plunger is getting stuck and holding a valve open.
Post: #23
(03-12-2016 )gearhead Wrote:  It's for sure intake valve? I wonder if jake plunger is getting stuck and holding a valve open.
i too thought this, but he has had a mechanic in the top end 3 times and they say it is all good. im assuming that they are telling the truth on this matter and the noise does definatly sound like a intake pulse
03-13-2016, (Subject: Popping like sound )
Post: #24
What about a slipped valve cam? How is the power? The jake sound would be coming on the exhaust side. Id remove the intake pipe and see if it is louder. Sounds like a thump sound. We had one in here a few months bad with a bad valve. but it had a skip and was smoking
Post: #25
Dirty DPF and leaking EGR
Post: #26
Power seems ok, lil spuddery, no smoke doc & dpf are clean the sound is loudest at air cleaners did the temp gun yesterday all cylinders are around same temp boroscope is next
Post: #27
Coco, Did you run the rpm's up to about 1300, when you checked the temp's at the exhaust manifold?
