Instrument cluster |
01-24-2021, (Subject: Instrument cluster ) Post: #1 | |||
Instrument cluster About a week ago my j1939 connecter stopped reporting to my elog. If i plug in a nexis iq it does not respond to that either. Now my issue is none of my gauges do a sweep when i turn the key on. The only thing that turns on is the stereo, hvac. All marker lights work. Headlights do not turn on. The hazards turn on when i turn the key on. Brake lights do not activate from pedal even though relay clicks. Throttle responds to input. Truck is a 2016 kenworth w900 | |||
01-24-2021, (Subject: Instrument cluster ) Post: #2 | |||
RE: Instrument cluster Update pulled cecu fuses because f$%k the cab controller and now i am back to no city horn, jakebrake, j1939 power | |||
01-24-2021, (Subject: Instrument cluster ) Post: #3 | |||
RE: Instrument cluster All switches are responsive now, my cab light were locked on so i pulling fuses to get those off and decided to pull cecu. Now everything is back to prior to its seizure | |||
01-24-2021, (Subject: Instrument cluster ) Post: #4 | |||
RE: Instrument cluster Kw cab controller is known to throw fits from time to time.. I'm my 660 I used to know what 3 fuses I had to pull to get it to reset. If you didn't pull all 3 ya was chasing ya tail. | |||
01-24-2021, (Subject: Instrument cluster ) Post: #5 | |||
RE: Instrument cluster this may help: http://rawze.com/forums/showthread.php?t...28#pid1628 it solves many a issue with petes and KW's with regard to having various electrical issues. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
01-24-2021, (Subject: Instrument cluster ) Post: #6 | |||
RE: Instrument cluster I read trough the thread. I have had the truck sit for about 3 days without batteries hooked up and my jake never came back. I think the cecu is going out and various pieces are shorting out over time. | |||
01-24-2021, (Subject: Instrument cluster ) Post: #7 | |||
RE: Instrument cluster I also forgot to mention that my cab lights do not turn on when i open the door. A setting i wanted but not from whatever is going on. | |||
