RIP CM2250, 2013, 800,000km 20,000 hrs |
03-09-2021, (Subject: RIP CM2250, 2013, 800,000km 20,000 hrs ) Post: #46 | |||
RE: RIP CM2250, 2013, 800,000km 20,000 hrs I’ll check the voltage if I get it to run tonight. How do I check voltage from ECM to sensors? I’m hunting down to see any shorts, but I might try to find a good automotive electrician to assist me with this, I just have a tester and multimeter from Who knows when. I could replace alternator run it and see, if it doesn’t go away I’ll just return alternator. But will check voltage. Are your thoughts along mine that this is a simple electrical issue somewhere? If those temp sensors aren’t expensive I could just replace them. | |||
03-09-2021, (Subject: RIP CM2250, 2013, 800,000km 20,000 hrs ) Post: #47 | |||
RE: RIP CM2250, 2013, 800,000km 20,000 hrs if ya can't figure it out, u might want to make an appt. with Mr. hags shop? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
03-16-2021, (Subject: RIP CM2250, 2013, 800,000km 20,000 hrs ) Post: #48 | |||
RE: RIP CM2250, 2013, 800,000km 20,000 hrs (03-09-2021 )Rawze Wrote: if ya can't figure it out, u might want to make an appt. with Mr. hags shop? If only I trucked further than a tesla can drive to without a battery boost, that would be an option. Local dumps here so that's a far stretch. I did get my Inline 6 in the mail today. Could someone PM me for assistance with the next steps, "next" steps. Now I can start, soon, isolating these def problems. Thanks in advance. | |||
03-17-2021, (Subject: RIP CM2250, 2013, 800,000km 20,000 hrs ) Post: #49 | |||
RE: RIP CM2250, 2013, 800,000km 20,000 hrs Never mind. Success. Google is a friend sometimes. So far got it working on windows 8. Will connect to truck in coming days. Exciting times coming. | |||
03-20-2021, (Subject: RIP CM2250, 2013, 800,000km 20,000 hrs ) Post: #50 | |||
RE: RIP CM2250, 2013, 800,000km 20,000 hrs Alright, finally got insite and hooked it up. First thing I did was injector leakdown test, and this is on a newly rebuilt motor.. It failed. Dropped 9,000 PSI in 1 minute. Next thing i'm going to do is the cylinder cut out test the way Rawze shows. I also looked at the aftertreatment history, and below is what I got. Also looked at engine use history, but it's bene rebuilt since then and I've only had it for 1,000 or so hours. Anything else I should be doing at this stage to start investigating into the health of this boy. FYI - SCR replaced 100 hours ago. Getting a code consistently for low def pressure low (FC 3574). ![]() ![]() | |||
