RIP CM2250, 2013, 800,000km 20,000 hrs |
05-14-2022, (Subject: RIP CM2250, 2013, 800,000km 20,000 hrs ) Post: #73 | |||
RE: RIP CM2250, 2013, 800,000km 20,000 hrs (05-14-2022 )Hermjeji Wrote:(05-06-2022 )Rawze Wrote: maybe monitor the commanded vs measured pressures and see if there are pressure spikes?. So far, it does not look that unusual besides failing a leak test. It is normal for the pressure to fluctuate about 200~ish bar or so. The fuel system pressure regulation works like any other hydraulic bypass-charging system, so the up/down fluctuations are normal within that range. 300 bar (if memory serves me right), maybe is max before setting off alarms. Just for FYI purposes: - Unlike a low pressure hydraulic system with a spring regulator...,. a hydraulic bypass-charging pressure regulation works by closing a valve so that the pump can make/build up the pressure. Once the pressure is reached, then the valve opens again, putting the pump into 'neutral' .. not allowing it to supply anything until the pressure has fallen off again by a certain amount. .,. then the valve shuts again to top it off whenever it is needed only. - this makes the pressure go up and down constantly by a few % as the fluid gets consumed, does work, etc. and the valve opens and closes due to pressure drops. It is the equivalent of a truck going down the road and the driver shifting it in and out of gear, back into neutral once it gets up to speed... and then going back into gear after it slows down a bit, so that the average speed can be kept up ... unlike one that may have the the cruise control set and remaining in gear all the time, keeping a very steady speed,,. always in gear, wearing things out. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
06-14-2022, (Subject: RIP CM2250, 2013, 800,000km 20,000 hrs ) Post: #74 | |||
RE: RIP CM2250, 2013, 800,000km 20,000 hrs So. Head #6, new actuator, new fuel pump actuator housing, new fuel pressure relief valve. After 12 hours of operating, started losing power again. It's failing the leakdown test now, but it can't make pressure above 20,000 psi. No visible leaking on the top of the head yet, but I assume another several hours of running and it would start. I am getting an odd ticking sound coming from the main rail line (also when the key is turned on, it takes a while for the usual ticking noise of the pressure being built up to stop). I'm going to pull the valve cover off, and see if something else is going on (also due for an overhead). But, could anything on the top end be causing these repeated fuel pump heads to go? I don't know what to do at this point. | |||
06-14-2022, (Subject: RIP CM2250, 2013, 800,000km 20,000 hrs ) Post: #75 | |||
RE: RIP CM2250, 2013, 800,000km 20,000 hrs (06-14-2022 )Hermjeji Wrote: So. I would not think so, but one never knows in an odd, extreme case like that. Maybe a severely leaky injector with its internal check-valve failed, back-feeding cylinder pressures into the rail?, but that would also mean it fails a leak-down test. It almost sounds to me like bad fuel.. or contaminants keep getting in .. perhaps something letting coolant in the fuel, air, something causing repeated pump failures. Otherwise, fuel pumps do not just fail over and over completely on their own unless someone is using aftermarket (or the wrong ) parts in them. Are the bottom of the fuel tanks clean and free of coolant, moisture, etc?. upon inspecting them with a bright light? Does the commanded fuel pressure vs. the measured show a higher pressures than commanded?. and/or when test driving it at high engine loads? Also, make sure the ecm does not have a crappy delete program in it. It could be over-working the pump .. that can happen too, but I doubt even that would cause failures so often. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
