| Insite |
| 03-11-2021, (Subject: Insite ) Post: #1 | |||
| Insite Have a question it it normal to upgrade insite when you get it mine is 8.1 and it’s asking to be upgraded | |||
| 03-11-2021, (Subject: Insite ) Post: #2 | |||
| RE: Insite Prob not unless you need to. You may not need 8.1 either depending on the year of your truck, then you can stop paying the yearly fees. | |||
| 03-12-2021, (Subject: Insite ) Post: #3 | |||
| RE: Insite It’s a 2013 and have it put on the password in it says insite has expired upgrade | |||
| 03-12-2021, (Subject: Insite ) Post: #4 | |||
| RE: Insite If fees are paid up to date, prob will have to upgrade. | |||
| 03-12-2021, (Subject: Insite ) Post: #5 | |||
| RE: Insite Just want to say thank you to everyone that help me out with the insite it’s up and running Thank you again | |||
| 03-13-2021, (Subject: Insite ) Post: #6 | |||
| RE: Insite Having a problem with the inline 6 insite reading the ecm going to try again tomorrow I’m charging up the laptop | |||
| 03-13-2021, (Subject: Insite ) Post: #7 | |||
| RE: Insite | |||
| 03-13-2021, (Subject: Insite ) Post: #8 | |||
RE: Insite (03-13-2021 )amermextrucker Wrote:I hope it work going to try again tomorrow laptop died the laptop is old maybe that’s the problem?(03-13-2021 )JAsaro Wrote: Having a problem with the inline 6 insite reading the ecm going to try again tomorrow I’m charging up the laptop | |||
| 03-14-2021, (Subject: Insite ) Post: #9 | |||
| RE: Insite Update it’s working now I didn’t realize that the inline6 software wasn’t downloaded into the laptop | |||
