LED turnsignal hyper flash
08-07-2016, (Subject: LED turnsignal hyper flash )
Has anyone replaced the turn signal bulbs in the headlight bezel with LED bulbs? If so, is there a relay that can be replaced with an electronic relay, or is the only fix to the hyperflash is to go the resistor route?
I've searched all over for a relay that controls the truck.. there are 2 for the trailer, and when both are removed, the trailer won't flash.. but the truck continues. I'm guessing it's in the SAM somewheres..
User's Signature: 2012 Cascadia ISX15 CM2250
09-01-2016, (Subject: LED turnsignal hyper flash )
RE: LED turnsignal hyper flash
I think it's built in the SAM, i was going to replace the regular bulbs because they are getting too hot and they are burning my headlights, but after looking for LED bulbs for awhile, i decided to leave it this way, let us know if you find good LEDs, i think i saw LEDs with built in resistors, good luck
This place has some top of the line products. They have an assortment of resistors. I've bought led headlights ( JW Speaker) and they are a good place to buy from.
http://www.xenondepot.com
