| Fuel pressure CM 871 |
| 06-28-2021, (Subject: Fuel pressure CM 871 ) Post: #1 | |||
| Fuel pressure CM 871 A year ago I got fuel pressure differential code 2372 in hot weather in a long pull. It would go away after key turn. Checked fuel pressure which was borderline and replaced pump. It had over a million miles on it. The problem didn’t return until lately, again in hot weather in a pull. Lately I’ve gotten 2372 pressure differential, and 482, 2215 low fuel pressure. A few of the times it feels like the power is cut back some all of a sudden. Otherwise the truck runs fine. Any ideas? | |||
| 06-28-2021, (Subject: Fuel pressure CM 871 ) Post: #2 | |||
| RE: Fuel pressure CM 871 See my post here to the CM870 problem http://rawze.com/forums/showthread.php?tid=7419 Might help. | |||
