|  ISX 871 SKIPPING  |
|  08-18-2021, (Subject: ISX 871 SKIPPING )  Post: #1 | |||
| ISX 871 SKIPPING  2009 isx when I come to a stop it starts skipping not all the time. And not often. Truck runs and pulls fine. When this happ and I start to drive I see a puff of black smoke left behind me  | |||
|  08-18-2021, (Subject: ISX 871 SKIPPING )  Post: #2 | |||
| RE: ISX 871 SKIPPING  check for leaky injectors. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  08-20-2021, (Subject: ISX 871 SKIPPING )  Post: #3 | |||
| RE: ISX 871 SKIPPING  I might be imagining things but I added some HOWS with my last fill and the skipping is less and infrequent...  | |||
|  08-25-2021, (Subject: ISX 871 SKIPPING )  Post: #4 | |||
| RE: ISX 871 SKIPPING  Update I think I figured it out. Ok hear is an update I ran the last 2 days with the Jake off. The violent skipping has stopped..so my Jake on 3 cylinders is a problem. Is that going to be the solenoid? I still have an occasional skip at idle and when I accelerate I get a light puff of smoke wich leads me to belive i have a bad injector... | |||
|  09-19-2021, (Subject: ISX 871 SKIPPING )  Post: #5 | |||
| RE: ISX 871 SKIPPING  Update again I did bubble test with key only. It failed on both banks so I decided to do a 6 pack. I also noticed some oil at the plug for the Jake and some frayed insulation on the wiring harness. So I ordered 2 Jake solenoids and a new harness. Waiting on them to arive. | |||
