|  AC COLD Driving & Warm Parked  |
|  08-20-2021, (Subject: AC COLD Driving & Warm Parked )  Post: #1 | |||
| AC COLD Driving & Warm Parked  My 2014 Prostar AC Blows so cold I can’t leave it on long while Driving and when I stop it blows like it’s not even AC at all and if I bump up the RPMs it’s a bit better but nothing like driving and cursing RPMs are 1500  | |||
|  08-20-2021, (Subject: AC COLD Driving & Warm Parked )  Post: #2 | |||
| RE: AC COLD Driving & Warm Parked  Maybe a dirty condenser that only gets enough air flow through it when driving????  | |||
|  08-20-2021, (Subject: AC COLD Driving & Warm Parked )  Post: #3 | |||
| RE: AC COLD Driving & Warm Parked  It would probably be easier to figure if it wasn’t working at all, thank you for the tip it’s going on the list of things to check, I was hoping someone’s had this problem but I figured it’s not a huge deal because it removes the incentive to idle my truck.  | |||
|  08-20-2021, (Subject: AC COLD Driving & Warm Parked )  Post: #4 | |||
| RE: AC COLD Driving & Warm Parked  Manifold gauges would certainly help. Guessing isn't usually a very efficient way to troubleshoot anything. https://www.harborfreight.com/ac-r134a-m...60806.html | |||
|  08-22-2021, (Subject: AC COLD Driving & Warm Parked )  Post: #5 | |||
| RE: AC COLD Driving & Warm Parked  Is the fan comin on when parked?  | |||
|  08-22-2021, (Subject: AC COLD Driving & Warm Parked )  Post: #6 | |||
| RE: AC COLD Driving & Warm Parked  The fan comes on every so often, while parked but it doesn’t just stay on, I spoke to a member here directly who recently had this same issue as well as another member also having this issue all with their Prostars so I think I’ve found a solution but thank you for your reply anyways  | |||
|  08-26-2021, (Subject: AC COLD Driving & Warm Parked )  Post: #7 | |||
| RE: AC COLD Driving & Warm Parked  So Demandating Fixed this Warm AC when parked I know it probably unrelated but she blows ICE COLD all the time now  | |||
