Can I use the same method? |
11-22-2021, (Subject: Can I use the same method? ) Post: #1 | |||
Can I use the same method? I'm looking to purchase another truck this new to me truck has a c15 caterpillar and I'd like to do a compression test. In one of rawze videos he made a pvc pipe with clear tubing device to monitor the compression coming from the engine. My question is can this same method be performed on a c15 acert thanks in advance | |||
11-22-2021, (Subject: Can I use the same method? ) Post: #2 | |||
RE: Can I use the same method? I think you are referring to the manometer test, it gives you some idea of how much blowby the engine is producing. This is entirely different than a compression test but yes it will work on the Cat. User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
