Cm2250 Rear Seal |
11-22-2021, (Subject: Cm2250 Rear Seal ) Post: #1 | |||
Cm2250 Rear Seal I ordered a new rear seal and it came with a plastic spacer? ring ( see pic). I am a little confused what this is for, Does this allow me to install the seal with a soft hammer instead of the special tool? | |||
11-22-2021, (Subject: Cm2250 Rear Seal ) Post: #2 | |||
RE: Cm2250 Rear Seal register the engine ser# on quickserv.com.. and follow the instructions for replacing the seal. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
11-23-2021, (Subject: Cm2250 Rear Seal ) Post: #3 | |||
RE: Cm2250 Rear Seal The plastic spacer fits inside the seal installer and meets the flywheel housing to set the depth of the seal. Sure you could use it as-is with a hammer, but for the work involved in redoing it.... I would consider paying a mechanic, friend or dealer to come out with the right tools and install it correctly. | |||
11-25-2021, (Subject: Cm2250 Rear Seal ) Post: #4 | |||
RE: Cm2250 Rear Seal Amazon also has the tool needed. I've used mine twice. It works fantastic. 3164780 Crankshaft Rear Main Seal & Wear Sleeve Installer & Seal Remover Tool for Cummins ISX QSX ISX15 ISX12 https://amzn.to/3d4wNA9 | |||
