| EGR Cooler Bypass kit |
| 02-01-2022, (Subject: EGR Cooler Bypass kit ) Post: #1 | |||
| Gentleman, hope you’re all well. Anybody know of a good quality bypass kit? Example:{link removed by Rawze} Have read previous posts explaining all the shonky kits being sold online. Cheers | |||
| 02-01-2022, (Subject: EGR Cooler Bypass kit ) Post: #2 | |||
| RE: EGR Cooler Bypass kit What’s the purpose behind this if the truck is deleted? | |||
| 02-01-2022, (Subject: EGR Cooler Bypass kit ) Post: #3 | |||
| RE: EGR Cooler Bypass kit {post removed by Rawze.. Advertising} User's Signature: Professional Window Licker | |||
| 02-01-2022, (Subject: EGR Cooler Bypass kit ) Post: #4 | |||
RE: EGR Cooler Bypass kit (02-01-2022 )kozakvod Wrote: What’s the purpose behind this if the truck is deleted? The purpose is to get proper cooling to #5 cylinder's. Eliminating the egr cooler is known to cause premature water pump failures and overheating of those cylinder's I mentioned. It's not a good idea to eliminate your egr cooler but if you must do it, you have to replace it with another way to get coolant back there. | |||
| 02-01-2022, (Subject: EGR Cooler Bypass kit ) Post: #5 | |||
| RE: EGR Cooler Bypass kit best thing to do is simply leave the EGR cooler in place.. replace it if it gets leaky. no fuss, no mess, no problems,.. and no failed inspections/ fines!. ========= BY the way... the kit in that pic looked to be complete garbage!. paper thin plates destined to break apart and go thru your turbo (or intake), destroying it after a while. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
