CM871 ECM failure
04-12-2022, (Subject: CM871 ECM failure )
CM871 ECM failure
Well, one of the few parts I didn’t replace during my inframe, the ECM, looks like it decided to quit today.
I’m getting a stop engine light, engine stall, and a flurry of inactive codes, with the active code being ‘ecm power lost with ignition on’. I can start the engine, tap the ecm and it stalls. Likewise, I can tap the ecm with the ignition on and it will cause the fuel pump prime and a number of other things to stop and start all over again. All about the time the engine comes up to temp.
Is there a common failure point in these (ribbon cable, solder joints) that cause these types of issues in these ecms or am I pretty much doomed to a new ecm? It has @m*m^2 in it so I’m trying to be mindful of that when going through my options.
Overhauled @ 927k
RE: CM871 ECM failure
Pull the file with calterm. Put on a new ECM and download the file to it. Usually a ribbon connector shorts out on the casing of the ECM - Probably best left alone. The ECM case opens up like a book and both sides are siliconed down. They usually get destroyed when you try to open them up.
 Thanks given by: Rawze , dhirocz
That’s it? Just put the new one and flash it? Shouldn’t be an issue.
Just need to put calterm on my scanning laptop. I’ll let you know if I have issues. Thank you!
Overhauled @ 927k
