| 2015 ProStar temp sensor harness |
| 05-13-2022, (Subject: 2015 ProStar temp sensor harness ) Post: #1 | |||
| 2015 ProStar temp sensor harness Greetings all, I have a 2015 ProStar with a Cummins ISX. I'm trying to replace the wiring harness for the ambient air temperature sensor. My sensor is located on the bumper and I tried to trace it back but ran into a big wire junction with a wire protector wrapped around it. I was wonqdering if anyone knew where it plugged in at so I can run it directly to that point without taking apart all the wire protectors. I have attached a picture of the harness.[/size] | |||
| 05-13-2022, (Subject: 2015 ProStar temp sensor harness ) Post: #2 | |||
| RE: 2015 ProStar temp sensor harness on some models it is located under/behind the front of the bumper hidden in the wiring harness that runs behind the radiator .. on other models, it is in the wiring harness up by the engine .. and still others, it is located inside one of the side mirrors. maybe this post helps... http://rawze.com/forums/showthread.php?t...2#pid14642 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 05-13-2022, (Subject: 2015 ProStar temp sensor harness ) Post: #3 | |||
| RE: 2015 ProStar temp sensor harness I know where the sensor is located.. I was wondering where the other end of the wiring harness plugs into. If you look at the picture I'm talking about the end with the red tab. | |||
