When do I replace spring bushings?
06-18-2022, (Subject: When do I replace spring bushings? )
How do I know it’s time to replace spring bushings?
RE: When do I replace spring bushings?
depends on the type of springs and bushings. The service manual for the brand/make of axle is likely the place to find those answers.
 Thanks given by: Redland1
06-19-2022, (Subject: When do I replace spring bushings? )
If you take most of the weight of the chassis with a jack and move the spring shackles with a bar you'll see how much movement they have. You'll also notice a clunk or knock when you quickly turn both ways like at a roundabout if they have a fair bit of movement.
 Thanks given by: Redland1 , Rawze
(06-18-2022 )Rawze Wrote:  depends on the type of springs and bushings. The service manual for the brand/make of axle is likely the place to find those answers.
I’m going to see if I could find the manual.Would a spring shop be the best place to get it looked at?
