DD15 rods and mains |
03-01-2023, (Subject: DD15 rods and mains ) Post: #1 | |||
DD15 rods and mains Looking for real data on when I should have my rods and main bearings done. Oil sampling is good. 722149 on the mileage. Don't just want to tear into the engine for no reason. | |||
03-01-2023, (Subject: DD15 rods and mains ) Post: #2 | |||
RE: DD15 rods and mains I think it is about 600k miles on them. If you don't do them, no harm will become of it ... that is, until some idiot replaces the fuel filter and the oil filter at the same time together without cranking the engine in between.. and then it will spin a bearing, ruining the crank. some related info: http://rawze.com/forums/showthread.php?t...0#pid61520 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
03-02-2023, (Subject: DD15 rods and mains ) Post: #3 | |||
RE: DD15 rods and mains Replace oil manifold and pickup tube o-rings as well | |||
03-04-2023, (Subject: DD15 rods and mains ) Post: #4 | |||
RE: DD15 rods and mains Yea… what they said. If your dd15 has a “plastic” oil suction module there is a small square plug on them that will blow out around 700k-800k miles and lock the engine up before you can pull over. I’ve got a pile of them at the shop. Your engine is a timebomb if it hasn’t been changed. | |||
03-04-2023, (Subject: DD15 rods and mains ) Post: #5 | |||
RE: DD15 rods and mains Wow, and people say cummins are junk. | |||
03-04-2023, (Subject: DD15 rods and mains ) Post: #6 | |||
RE: DD15 rods and mains The ones that say Cummins are junk are the same ones that bought wore out trucks with no repair history, had the guy in another country tune their truck with a file that was purchased in bulk for $300, only serviced their truck because the oil pan started leaking and the oil had to come out anyways, and relied solely on a dealership to make their repairs. | |||
03-05-2023, (Subject: DD15 rods and mains ) Post: #7 | |||
RE: DD15 rods and mains (03-04-2023 )Bengy88 Wrote: The ones that say Cummins are junk are the same ones that bought wore out trucks with no repair history, had the guy in another country tune their truck with a file that was purchased in bulk for $300, only serviced their truck because the oil pan started leaking and the oil had to come out anyways, and relied solely on a dealership to make their repairs.Huge AMEN!! | |||
