| ISB fuel decay test |
| 11-07-2023, (Subject: ISB fuel decay test ) Post: #1 | |||
| ISB fuel decay test I haven't been able to find a definitive answer if the ISB 2250/2350 fuel decay/leak test specs are about the same with the 4000 psi drop over a minute. Most of what I find is more about measuring flow return rates similar to Duramax engines. Can you use the decay test on the ISBs like the ISX's? | |||
| 11-07-2023, (Subject: ISB fuel decay test ) Post: #2 | |||
| RE: ISB fuel decay test Ive done the test on my isc, not sure how similar isb and isc are. | |||
| 11-07-2023, (Subject: ISB fuel decay test ) Post: #3 | |||
| RE: ISB fuel decay test Yes it would be the same, doesn't matter which cummins common rail engine you have. | |||
