11-07-2023,
I haven't been able to find a definitive answer if the ISB 2250/2350 fuel decay/leak test specs are about the same with the 4000 psi drop over a minute. Most of what I find is more about measuring flow return rates similar to Duramax engines. Can you use the decay test on the ISBs like the ISX's?
