PSI and OIL ratings... |
09-23-2016, (Subject: PSI and OIL ratings... ) Post: #1 | |||
PSI and OIL ratings... I thought I would re-post this from the old forum. Supposedly they are listed from best to worst. Published: June 20, 2013 -- http://www.motoroiltests.com/ 1. Prolong Engine Treatment added to 5W30 Pennzoil Ultra, API SN synthetic = 136,658 psi 2. Prolong Engine Treatment added to 5W30 Castrol GTX, API SN conventional = 130,366 psi This oil on its own WITHOUT the Prolong Engine Treatment added to it, has a wear protection capability of 95,392 psi. With the recommended amount of Prolong added per qt, its wear protection capability “WENT UP 37%”. 3. Prolong Engine Treatment added to 5W30 Pennzoil, API SN conventional yellow bottle = 117,028 psi zinc = 806 ppm phosphorus = 812 ppm moly = 66 ppm calcium = 3,011 ppm TBN = 10.3 4. 5W30 Motul 300V Ester Core 4T Racing Oil, synthetic = 112,464 psi zinc = 1724 ppm phosphorus = 1547 ppm moly = 481 ppm calcium = 3141 ppm TBN = 7.4 5. “Oil Extreme concentrate” added to 5W30 Pennzoil Ultra, API SM synthetic = 111,570 psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of 115,612 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT DOWN 3.5%”. zinc = TBD phosphorus = TBD. moly = TBD calcium = TBD TBN = TBD 6. “Oil Extreme concentrate” added to 10W30 Brad Penn, Penn Grade 1 semi-synthetic = 111,061psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 71,206 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT UP A BREATH TAKING 56%”. zinc = TBD phosphorus = TBD. moly = TBD calcium = TBD TBN = TBD 7. 5W30 Oil Extreme Motor Oil, API SM synthetic (per the Oil Company, even though synthetic wording is not shown on the label) = 110,286 psi The Company claims this oil contains their proprietary formula of calcium petroleum sulfontate EP (Extreme Pressure) technology that is NOT found in any other motor oil. They also claim that it will provide 5 to 7 more HP, 7 to 10% better fuel mileage, cut engine wear in half, and will extend drain intervals two or three times safely. This oil is endorsed and promoted by Tech Author David Vizard. And he was so impressed by this oil’s performance that he also became a share holder in the Company. The results from the “Dynamic Wear Testing Under Load” performed here, fully supports their claim regarding wear protection. So, their hype about that, turned out to be absolutely true. And since this oil beat every high zinc oil I’ve ever tested, it also proved another one of their claims, that using zinc as the primary anti-wear component, is outdated technology. zinc = 765 ppm phosphorus = 624 ppm moly = 52 ppm calcium = 7,652 ppm TBN = 23.2 8. 10W30 Lucas Racing Only synthetic = 106,505 psi NOTE: This oil is suitable for short term racing use only, and is not suitable for street use. zinc = 2642 ppm phosphorus = 3489 ppm moly = 1764 ppm calcium = 2,929 ppm TBN = 9.0 9. CFS 0W30 NT Millers Nanodrive Racing Oil, API SM synthetic = 105,907 psi This oil is from England, comes in liter bottles (slightly more than a quart), and it uses a nanotechnology formulation. At the time this oil was tested in fall 2013, it cost $22.45 per bottle. And with the shipping cost added to that, the final cost was about $28.00 per bottle (shipping was all inside the U.S.), making it one of the most expensive oil I’ve ever tested. zinc = TBD phos = TBD moly = TBD calcium = TBD TBN = TBD 10. 5W30 Mobil 1, API SN synthetic = 105,875 psi zinc = 801 ppm phosphorus = 842 ppm moly = 112 ppm calcium = 799 ppm TBN = 7.5 11. “Oil Extreme concentrate” added to 10W30 Lucas Hot Rod & Classic Hi-Performance Oil conventional = 105,758 psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 62,538 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT UP A MIND BLOWING 69%”. zinc = TBD phosphorus = TBD moly = TBD calcium = TBD TBN = TBD 12. 0W30 Amsoil Signature Series 25,000 miles, API SN synthetic = 105,008 psi zinc = 824 ppm phosphorus = 960 ppm moly = 161 ppm calcium = 3,354 ppm TBN = 11.4 13. 5W30 Joe Gibbs Driven LS30 Performance Motor Oil, synthetic = 104,487 psi The bottle says it is formulated specifically for high output GM LS engines, and that no ZDDP or additives required. This is by far, the best performing Joe Gibbs oil I’ve ever tested. It is at the very top of the OUTSTANDING wear protection category, and fell just short of the INCREDIBLE wear protection category. This oil contains sufficient amounts of the components required (detergent, acid neutralizer, etc) for normal change intervals in street driven vehicles. But, it has way too much zinc/phos for use in cat equipped vehicles. However, it is well suited for Race Cars, Street Hotrods and Classic cars. zinc = 1610 ppm phosphorus = 1496 ppm moly = 0 ppm calcium = 3515 ppm TBN = 8.8 14. 10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi NOTE: This oil is suitable for short term racing use only, and is not suitable for street use. zinc = 1669 ppm phosphorus = 1518 ppm moly = 784 ppm calcium = 1,607 ppm TBN = 4.4 15. 5W50 Motorcraft, API SN synthetic = 103,517 psi zinc = 606 ppm phosphorus = 742 ppm moly = 28 ppm calcium = 1,710 ppm TBN = 6.7 16. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi zinc = 1472 ppm phosphorus = 1544 ppm moly = 3 ppm calcium = 2,707 ppm TBN = 7.6 17. 5W30 Amsoil Series 3000 Heavy Duty Diesel Oil synthetic, API CI-4 PLUS, CF, SL, ACEA A3/B3, E2, E3, E5, E7 = 102,642 psi This is BY FAR, the highest ranked Diesel oil I have ever tested. This oil is Engineered for Diesel engines not equipped with Diesel particulate filters (DPF). Amsoil says this oil delivers better wear protection than other popular Diesel oils. And in this case, their hype is absolutely true. They also say it effectively reduces fuel consumption, with its advanced fuel efficient formula. This oil costs $11.15 per quart in the 2013 Amsoil Factory Direct Retail Catalog, which is 10% more than Amsoil’s 5W40 Premium Synthetic Diesel Oil. So, in this case, you pay only 10% more for the Amsoil Series 3000 Heavy Duty Diesel Oil, but you get a whopping 33% more wear protection than you get with the Amsoil’s 5W40 Premium Synthetic Diesel Oil. Money very well spent, if you run a Diesel oil intended for engines not equipped with Diesel particulate filters. The next highest ranked Diesel oil ranks far lower on the ranking list. So, this 5W30 Amsoil Series 3000 Heavy Duty Diesel Oil is in a class of its own, among all the Diesel oils I have tested. zinc = TBD phos = TBD moly = TBD 18. “Oil Extreme concentrate” added to 5W30 Mobil 1, API SN synthetic = 102,059 psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of 105,875 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT DOWN 3.6%”. zinc = TBD phosphorus = TBD. moly = TBD calcium = TBD TBN = TBD 19. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi zinc = 1180 ppm phosphorus = 1112 ppm moly = 162 ppm calcium = 2,664 ppm TBN = 7.4 20. “Oil Extreme concentrate” added to 5W30 Pennzoil, API SN conventional, yellow bottle = 100,252 psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 76,989 psi. But, with 1.5 OZ of concentrate added per qt, which is the bottle’s instruction for street driven vehicles, its wear protection capability “WENT UP A WHOPPING 30%”. zinc = 970 ppm moly = 285 ppm phosphorus = 749 ppm, this value is 91 ppm lower than the basic oil because the concentrate has less phosphorus in it, which diluted the overall ppm count of the mixture. calcium = 4,443 ppm TBN = 18.8 21. 5W30 Chevron Supreme, API SN conventional = 100,011 psi This oil only cost $4.29 per quart at an Auto Parts Store when I bought it. zinc = 1018 ppm phos = 728 ppm moly = 161 ppm 22. 5W20 Castrol Edge with Titanium, API SN synthetic = 99,983 psi zinc = 1042 ppm phos = 857 ppm moly = 100 ppm titanium = 49 ppm 23. 5W30 Pennzoil Platinum, API SN synthetic = 99,949 psi This was the original API SN version, that was NOT made from natural gas. zinc = TBD phos = TBD moly = TBD 24. “Oil Extreme concentrate” added to 5W30 Pennzoil, API SN conventional, yellow bottle = 99,529 psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 76,989 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT UP 29%”. zinc = TBD phos = TBD moly = TBD 25. 5W30 Pennzoil “Ultra” Platinum, Pure Plus Technology, made from pure natural gas, API SN = 99,039 psi This oil was introduced in 2014, and comes in a dark gray bottle with a blue vertical stripe on the label. zinc = TBD phos = TBD moly = TBD 26. “Oil Extreme concentrate” added to 5W30 Oil Extreme Motor Oil, API SM synthetic = 98,396 psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of 110,286 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT DOWN 11%”. zinc = TBD phos = TBD moly = TBD 27. “Oil Extreme concentrate” added to 5W30 Pennzoil, API SN conventional, yellow bottle = 97,651 psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 76,989 psi. But, with 3.0 OZ of concentrate added per qt, its wear protection capability “WENT UP 27%”. zinc = TBD phos = TBD moly = TBD 28. 10W30 Amsoil Dominator Racing Oil synthetic = 97,118 psi zinc = 1613 ppm phos = 1394 ppm moly = 0 ppm 29. “Oil Extreme concentrate” added to 5W30 Pennzoil, API SN conventional, yellow bottle = 96,739 psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 76,989 psi. But, with 4.0 OZ of concentrate added per qt, its wear protection capability “WENT UP 26%”. zinc = TBD phos = TBD moly = TBD 30. 20W50 Castrol GTX, API SN conventional = 96,514 psi zinc = 610 ppm phos = 754 ppm moly = 94 ppm 31. 30 wt Red Line Race Oil synthetic = 96,470 psi NOTE: This oil is suitable for short term racing use only, and is not suitable for street use. zinc = 2207 ppm phos = 2052 ppm moly = 1235 ppm 32. 0W20 Mobil 1 Advanced Fuel Economy, API SN synthetic = 96,364 psi zinc = 742 ppm phos = 677 ppm moly = 81 ppm 33. 5W30 Quaker State Ultimate Durability, API SN synthetic = 95,920 psi zinc = 877 ppm phos = 921 ppm moly = 72 ppm 34. 5W30 Castrol Edge with Titanium, API SN synthetic = 95,717 psi zinc = 818 ppm phos = 883 ppm moly = 90 ppm titanium = 44 ppm 35. 10W30 Joe Gibbs XP3 NASCAR Racing Oil synthetic = 95,543 psi NOTE: This oil is suitable for short term racing use only, and is not suitable for street use. zinc = 743 ppm phos = 802 ppm moly = 1125 ppm 36. 5W20 Castrol GTX, API SN conventional = 95,543 psi NOTE: The two oils above were tested weeks apart, but due to the similarities in their wear scar sizes, their averages ended up the same. zinc = TBD phos = TBD moly = TBD 37. 5W30 Castrol GTX ,API SN conventional = 95,392 psi zinc = 830 ppm phos = 791 ppm moly = 1 ppm 38. 10W30 Amsoil Z-Rod Oil synthetic = 95,360 psi zinc = 1431 ppm phos = 1441 ppm moly = 52 ppm 39. 5W30 Havoline, API SN conventional = 95,098 psi zinc = TBD phos = TBD moly = TBD 40. 5W30 Valvoline SynPower, API SN synthetic = 94,942 psi zinc = 969 ppm phos = 761 ppm moly = 0 ppm 41. “Oil Extreme concentrate” added to 5W30 Chevron Supreme, API SN conventional = 94,864 psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of 100,011 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT DOWN 5.1%”. zinc = TBD phosphorus = TBD. moly = TBD 42. 5W30 Valvoline Premium Conventional, API SN = 94,744 psi zinc = TBD phos = TBD moly = TBD 43. 5W20 Mobil 1, API SN synthetic = 94,663 psi zinc = 764 ppm phos = 698 ppm moly = 76 ppm 44. 5W20 Valvoline SynPower, API SN synthetic = 94,460 psi zinc = 1045 ppm phos = 742 ppm moly = 0 ppm 45. 5W30 Pennzoil Ultra, API SN synthetic = 92,569 psi This was the original API SN version, that was NOT made from natural gas. The older API “SM” version of this oil, produced a wear protection capability value of 115,612 psi. zinc = TBD phos = TBD moly = TBD 46. 5W30 Lucas, API SN conventional = 92,073 psi zinc = 992 ppm phos = 760 ppm moly = 0 ppm 47. 5W30 O’Reilly (house brand), API SN conventional = 91,433 psi This oil only cost $3.99 per quart at an Auto Parts Store when I bought it. zinc = 863 ppm phos = 816 ppm moly = 0 ppm 48. 5W30 Maxima RS530 Synthetic Racing Oil = 91,162 psi zinc = 2162 ppm phos = 2294 ppm moly = 181 ppm 49. 5W30 Red Line, API SN synthetic = 91,028 psi zinc = TBD phos = TBD moly = TBD 50. 5W20 Royal Purple API SN synthetic = 90,434 psi zinc = 964 ppm phos = 892 ppm moly = 0 ppm 51. 10W30 Quaker State Defy, API SL semi-synthetic = 90,226 psi zinc = 1221 ppm phos = 955 ppm moly = 99 ppm 52. 10W60 Castrol TWS Motorsport, API SJ conventional = 90,163 psi This oil is manufactured in Europe and is sold in the US for BMW models M3, M5, M6, Z4M, and Z8. zinc = TBD phos = TBD moly = TBD 53. 5W20 Valvoline Premium Conventional, API SN = 90,144 psi zinc = TBD phos = TBD moly = TBD 54. “Oil Extreme concentrate” added to 5W30 Castrol GTX, API SN conventional = 89,659 psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of 95,392 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT DOWN 6%”. zinc = TBD phosphorus = TBD. PSI and oil ratings.txt 21 / 29 moly = TBD 55. 5W30 Havoline, API SN synthetic = 89,406 psi zinc = TBD phos = TBD moly = TBD 56. 30 wt Castrol Heavy Duty, API SM conventional = 88,089 psi zinc = 907 ppm phos = 829 ppm moly = 56 ppm 57. 20W50 LAT Synthetic Racing Oil, API SM = 87,930 psi zinc = TBD phos = TBD moly = TBD 58. 5W30 Valvoline Nextgen 50% Recycled Oil, API SN conventional = 87,563 psi zinc = 947 ppm phos = 778 ppm moly = 0 ppm 59. 5W30 Pennzoil Platinum, Pure Plus Technology, made from pure natural gas, API SN = 87,241 psi This oil was introduced in 2014, and comes in a silver bottle with a blue vertical stripe on the label. zinc = TBD phos = TBD moly = TBD 60. 10W30 Joe Gibbs HR4 Hotrod Oil synthetic = 86,270 psi zinc = 1247 ppm phos = 1137 ppm moly = 24 ppm 61. 5W20 Pennzoil Ultra, API SM synthetic = 86,034 psi zinc = TBD phos = TBD moly = TBD 62. 15W40 RED LINE Diesel Oil synthetic, API CJ-4/CI-4 PLUS/CI-4/CF/CH-4/CF-4/SM/SL/ SH/EO-O = 85,663 psi zinc = 1615 ppm phos = 1551 ppm moly = 173 ppm 63. 5W30 Castrol Edge w/Syntec, API SN (formerly Castrol Syntec) black bottle, synthetic = 85,179 psi zinc = TBD phos = TBD moly = TBD 64. 5W30 Royal Purple API SN synthetic = 84,009 psi zinc = 942 ppm phos = 817 ppm moly = 0 ppm 65. 20W50 Royal Purple API SN synthetic = 83,487 psi zinc = 588 ppm phos = 697 ppm moly = 0 ppm 66. 20W50 Kendall GT-1 High Performance with liquid titanium, API SN conventional = 83,365 psi zinc = 991 ppm phos = 1253 ppm moly = 57 ppm titanium = 84 ppm 67. 5W30 Mobil 1 Extended Performance 15,000 mile, API SN synthetic = 83,263 psi zinc = 890 ppm phos = 819 ppm moly = 104 ppm 68. 0W20 Castrol Edge with Titanium, API SN synthetic = 82,867 psi zinc = TBD phos = TBD moly = TBD 69. 0W40 Mobil 1, API SN, European Formula, made in the U.S., synthetic = 82,644 psi zinc = TBD phos = TBD moly = TBD 70. 0W40 Pennzoil Ultra, API SN, synthetic = 81,863 psi zinc = TBD phos = TBD moly = TBD 71. 5W30 LAT Synthetic Racing Oil, API SM = 81,800 psi zinc = 1784 ppm phos = 1539 ppm moly = 598 ppm 72. “Oil Extreme concentrate” added to 5W30 Royal Purple XPR (extreme performance racing oil) synthetic = 81,723 psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 74,860 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT UP 9%”. zinc = TBD phos = TBD moly = TBD 73. 0W30 Mobil 1, API SN, Advanced Fuel Economy, synthetic = 81,240 psi zinc = TBD phos = TBD. moly = TBD 74. 5W30 Peak, API SN synthetic = 80,716 psi zinc = TBD phos = TBD moly = TBD 75. 5W30 Edelbrock “Cat-Safe”, API SM synthetic = 78,609 psi This oil is made for Edelbrock by Torco zinc = 924 ppm phos = 659 ppm moly = 28 ppm 76. 30wt Amsoil Break-In Oil conventional = 78,192 psi zinc = 2051 ppm phos = 1917 ppm moly = 0 ppm 77. 20W50 Resolute Racing Oil, API SN conventional = 77,554 psi This oil cost only $2.49 per quart when bought for this test. It is a Regional Oil from the Mid-Western U.S. farm country. zinc = TBD phos = TBD moly = TBD 78. 5W40 Amsoil Premium Diesel Oil synthetic, API CJ-4, CI-4 PLUS, CF, SN, SM, ACEA E7, E9 = 77,207 psi zinc = TBD phos = TBD moly = TBD 79. 10W30 Renegade Pro Series Racing Oil, synthetic blend = 77,136 psi zinc = TBD, but bottle claims over 3000 ppm phos = TBD moly = TBD 80. 15W40 ROYAL PURPLE Diesel Oil synthetic, API CJ-4 /SM, CI-4 PLUS, CH-4, CI-4 = 76,997 psi zinc = TBD phos = TBD moly = TBD 81. 5W30 Pennzoil, API SN yellow bottle, conventional = 76,989 psi zinc = 839 ppm phos = 840 ppm moly = 267 ppm 82. 10W40 Chevron Supreme, API SN conventional = 76,806 psi zinc = TBD phos = TBD moly = TBD 83. 5W30 Lucas API SM synthetic = 76,584 psi zinc = 1134 ppm phos = 666 ppm moly = 0 ppm 84. 5W30 GM’s AC Delco dexos 1 API SN semi-synthetic = 76,501 psi zinc = 878 ppm phos = 758 ppm moly = 72 ppm 85. 5W50 Castrol Edge with Syntec API SN, synthetic, formerly Castrol Syntec, black bottle = 75,409 psi zinc = 1252 ppm phos = 1197 ppm moly = 71 ppm 86. “Oil Extreme concentrate” added to 10W30 Comp Cams Muscle Car & Street Rod Oil semi-synthetic = 74,874 psi This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 60,413 psi. But, with 2.0 OZ of concentrate added per qt, which is the amount intended for racing, its wear protection capability “WENT UP AN IMPRESSIVE 24%”. zinc = TBD phosphorus = TBD. moly = TBD 87. 5W30 Royal Purple XPR (Extreme Performance Racing) synthetic = 74,860 psi zinc = 1421 ppm phos = 1338 ppm moly = 204 ppm 88. 15W40 Cenpeco (Central Petroleum Company) S-3 Diesel Oil, conventional, API CI-4, CH-4, CG-4, CF, CE, CD, SL, SJ, SH = 74,593 psi zinc = TBD phos = TBD moly = TBD 89. 5W40 MOBIL 1 TURBO DIESEL TRUCK synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4 and ACEA E7 = 74,312 psi zinc = 1211 ppm phos = 1168 ppm moly = 2 ppm 90. 0W50 Mobil 1 Racing Oil = 73,811 psi zinc = 1676 ppm phos = 1637 ppm moly = 1263 ppm 91. 5W30 Peak, API SN conventional = 73,690 psi zinc = TBD phos = TBD moly = TBD 92. 15W40 CHEVRON DELO 400LE Diesel Oil, conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM, = 73,520 psi zinc = 1519 ppm phos = 1139 ppm moly = 80 ppm 93. 15W40 MOBIL DELVAC 1300 SUPER Diesel Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4/SM, SL = 73,300 psi zinc = 1297 ppm phos = 1944 ppm moly = 46 ppm 94. 15W40 Farm Rated Heavy Duty Performance Diesel Oil conventional CI-4, CH-4, CG-4, CF/SL, SJ = 73,176 psi zinc = 1325ppm phos = 1234 ppm moly = 2 ppm 95. 15W40 “NEW” SHELL ROTELLA T Diesel Oil conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM = 72,022 psi zinc = 1454 ppm phos = 1062 ppm moly = 0 ppm 96. Brad Penn, Penn Grade 1 Nitro 70 Racing Oil semi-synthetic = 72,003 psi zinc = TBD phos = TBD moly = TBD 97. 0W30 Mobil 1 Racing Oil = 71,923 psi zinc = 1693 ppm phos = 1667 ppm moly = 1326 ppm 98. 0W30 Brad Penn, Penn Grade 1 semi-synthetic = 71,377 psi zinc = 1621 ppm phos = 1437 ppm moly = 0 ppm 99. 15W40 “OLD” SHELL ROTELLA T Diesel Oil conventional, API CI-4 PLUS, CI-4, CH-4,CG-4,CF-4,CF,SL, SJ, SH = 71,214 psi Yes it’s true, the old Rotella actually has LESS zinc than the new Rotella. zinc = 1171 ppm phos = 1186 ppm moly = 0 ppm 100. 10W30 Brad Penn, Penn Grade 1 semi-synthetic = 71,206 psi zinc = 1557 ppm phos = 1651 ppm moly = 3 ppm 101. 15W40 VALVOLINE PREMIUM BLUE HEAVY DUTY DIESEL Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4, CG-4, CF-4, CF/SM = 70,869 psi PSI and oil ratings.txt 25 / 29 zinc = TBD phos = TBD moly = TBD 102. 15W50 Mobil 1, API SN synthetic = 70,235 psi zinc = 1,133 ppm phos = 1,168 ppm moly = 83 ppm 103. 10W40 Resolute All Season Motor Oil, API SN conventional = 69,709 psi This oil cost $2.49 per quart when bought for this test. It is a Regional Oil from the Mid-Western U.S. farm country. zinc = TBD phos = TBD moly = TBD 104. 5W40 CHEVRON DELO 400LE Diesel Oil synthetic, API CJ-4, CI-4 Plus, CI-4, SL, SM = 69,631 psi zinc = TBD phos = TBD moly = TBD 105. 0W40 Castrol Edge with Syntec (black bottle), API SN, European Formula, made in Belgium and sold in the U.S., synthetic = 69,307 psi zinc = TBD phos = TBD moly = TBD 106. 0W30 Castrol Edge with Syntec (black bottle), API SL, European Formula, made in Germany and sold in the U.S., synthetic = 69,302 psi zinc = TBD phos = TBD moly = TBD 107. 30wt Edelbrock Break-In Oil conventional = 69,160 psi zinc = 1545 ppm phos = 1465 ppm moly = 4 ppm 108. 5W30 Motorcraft, API SN synthetic = 68,782 psi zinc = 796 ppm phos = 830 ppm moly = 75 ppm 109. 10W40 Edelbrock synthetic = 68,603 psi This oil is manufactured for Edelbrock by Torco. zinc = 1193 ppm phos = 1146 ppm moly = 121 ppm 110. 5W30 Toyota Motor Oil, API SN conventional = 68,069 psi zinc = TBD phos = TBD moly = TBD 111. 5W40 SHELL ROTELLA T6 Diesel Oil synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4, SM, SL = 67,804 psi zinc = TBD phos = TBD moly = TBD 112. 15W40 LUCAS MAGNUM Diesel Oil, conventional, API CI-4,CH-4, CG-4, CF-4, CF/SL = 66,476 psi zinc = 1441 ppm phos = 1234 ppm moly = 76 ppm 113. 15W40 CASTROL GTX DIESEL Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4, CG-4, CF-4/SN = 66,323 psi zinc = TBD phos = TBD moly = TBD 114. 10W30 Royal Purple HPS (High Performance Street) synthetic = 66,211 psi zinc = 1774 ppm phos = 1347 ppm moly = 189 ppm 115. 10W40 Valvoline 4 Stroke Motorcycle Oil, API SJ conventional = 65,553 psi zinc = 1154 ppm phos = 1075 ppm moly = 0 ppm 116. 5W30 Klotz Estorlin Racing Oil, API SL synthetic = 64,175 psi zinc = 1765 ppm phos = 2468 ppm moly = 339 ppm 117. “ZDDPlus” added to Royal Purple 20W50, API SN, synthetic = 63,595 psi The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 24% LOWER than this oil had BEFORE the ZDDPlus was added to it. Most major Oil Companies say to NEVER add anything to their oils, because adding anything will upset the carefully balanced additive package, and ruin the oil’s chemical composition. And that is precisely what we see here. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. zinc = 2436 ppm (up 1848 ppm) phos = 2053 ppm (up 1356 ppm) moly = 2 ppm (up 2 ppm) 118. Royal Purple 10W30 Break-In Oil conventional = 62,931 psi zinc = 1170 ppm phos = 1039 ppm moly = 0 ppm 119. 10W30 Lucas Hot Rod & Classic Hi-Performance Oil, conventional = 62,538 psi zinc = 2116 ppm phos = 1855 ppm moly = 871 ppm 120. 0W20 Klotz Estorlin Racing Oil, API SL synthetic = 60,941 psi zinc = TBD phos = TBD moly = TBD 121. 10W30 Comp Cams Muscle Car & Street Rod Oil, synthetic blend = 60,413 psi This oil is manufactured for Comp Cams by Endure. zinc = 1673 ppm phos = 1114 ppm moly = 67 ppm 122. 10W40 Torco TR-1 Racing Oil with MPZ conventional = 59,905 psi zinc = 1456 ppm phos = 1150 ppm moly = 227 ppm 123. 10W40 Summit Racing Premium Racing Oil, API SL = 59,483 psi This oil is made for Summit by I.L.C. NOTE: This oil line was discontinued in Spring 2013. zinc = TBD phos = TBD moly = TBD 124. 10W40 Edelbrock conventional = 59,120 psi This oil is manufactured for Edelbrock by Torco. zinc = TBD phos = TBD moly = TBD 125. 0W20 LAT Synthetic Racing Oil, API SM = 57,228 psi zinc = TBD phos = TBD moly = TBD 126. “ZDDPlus” added to O’Reilly (house brand) 5W30, API SN, conventional = 56,728 psi The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 38% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. zinc = 2711 ppm (up 1848 ppm) phos = 2172 ppm (up 1356 ppm) moly = 2 ppm (up 2 ppm) 127. “ZDDPlus” added to Motorcraft 5W30, API SN, synthetic = 56,243 psi The amount of ZDDPlus added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 12% LOWER than this oil had BEFORE the ZDDPlus was added to it. Adding ZDDPlus SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. zinc = 2955 ppm (up 1848 ppm) phos = 2114 ppm (up 1356 ppm) moly = 76 ppm (up 2 ppm) 128. 0W Mobil 1 Racing Oil = 55,080 psi zinc = 1952 ppm phos = 1671 ppm moly = 1743 ppm 129. “Edelbrock Zinc Additive” added to Royal Purple 5W30, API SN, synthetic = 54,044 psi The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a whopping 36% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. zinc = 1515 ppm (up 573 ppm) phos = 1334 ppm (up 517 ppm) moly = 15 ppm (up 15 ppm) 130. 10W30 Comp Cams Break-In Oil conventional = 51,749 psi zinc = 3004 ppm phos = 2613 ppm moly = 180 ppm 131. “Edelbrock Zinc Additive” added to Lucas 5W30, API SN, conventional = 51,545 psi The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was a “breath taking” 44% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. zinc = 1565 ppm (up 573 ppm) phos = 1277 ppm (up 517 ppm) moly = 15 ppm (up 15 ppm) 132. “Edelbrock Zinc Additive” added to Motorcraft 5W30, API SN, synthetic = 50,202 psi The amount of Edelbrock Zinc Additive added to the oil, was the exact amount the manufacturer called for on the bottle. And the resulting psi value here was 22% LOWER than this oil had BEFORE the Edelbrock Zinc Additive was added to it. Adding Edelbrock Zinc Additive SIGNIFICANTLY REDUCED this oil’s wear prevention capability. Just the opposite of what was promised. zinc = 1680 ppm (up 573 ppm) phos = 1275 ppm (up 517 ppm) moly = 89 ppm (up 15 ppm) 133. 30wt Lucas Break-In Oil conventional = 49,455 psi zinc = 4483 ppm phos = 3660 ppm moly = 3 ppm User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
09-23-2016, (Subject: PSI and OIL ratings... ) Post: #2 | |||
RE: PSI and OIL ratings... Nice. So what do you think about the SuperTech brand from Walmart? | |||
09-23-2016, (Subject: PSI and OIL ratings... ) Post: #3 | |||
RE: PSI and OIL ratings... I see that the "new" Rotella has 0 Moly, and appears to be the only one without it. What are the wear protection properties of Moly, and is this significant? User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
09-23-2016, (Subject: PSI and OIL ratings... ) Post: #4 | |||
RE: PSI and OIL ratings... Thank you so very much, I missed this thread. User's Signature: It's hard to win an argument with a smart person, but it's damn near impossible to win an argument with a stupid person | |||
09-23-2016, (Subject: PSI and OIL ratings... ) Post: #5 | |||
RE: PSI and OIL ratings... User's Signature: It's hard to win an argument with a smart person, but it's damn near impossible to win an argument with a stupid person | |||
09-23-2016, (Subject: PSI and OIL ratings... ) Post: #6 | |||
RE: PSI and OIL ratings... I Also read that hydraulic aw46 has good additives, including zinc. User's Signature: It's hard to win an argument with a smart person, but it's damn near impossible to win an argument with a stupid person | |||
09-23-2016, (Subject: PSI and OIL ratings... ) Post: #7 | |||
RE: PSI and OIL ratings... (09-23-2016 )Hammerhead Wrote: I see that the "new" Rotella has 0 Moly, and appears to be the only one without it. What are the wear protection properties of Moly, and is this significant? Moly is up for great debate in the oil world. In grease it has very good protection properties and in engine oil it has always been viewed to be the same but as of late, engine oil companies have begun to question it's relevance. In fact, it has been shown that too much moly can accelerate wear. These companies need to find the right blend to get the benifits. Some have opted to just remove it all together. Moly is like zinc. Great to have but can actually hurt your engine if you have too much. User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
09-23-2016, (Subject: PSI and OIL ratings... ) Post: #8 | |||
RE: PSI and OIL ratings... For anybody interested the listing of oils has been updated as of September 17th. https://540ratblog.wordpress.com/2013/06...t-ranking/ What I found interesting was the "new" Mobil one European 0w40 with the "fs" on the bottle beat out every other oil he has tested straight out of the bottle. I just purchased 55 qts. From Wal-Mart to give it a try. Also I'very been looking at by-pass filters and narrowed it down to the Spinner II or Cummins centriguard. Anybody have experience with either of these on an ISX without doing the oil shim fix for higher pressure? | |||
09-25-2016, (Subject: PSI and OIL ratings... ) Post: #9 | |||
RE: PSI and OIL ratings... (09-23-2016 )schISM Wrote: ... Also I'very been looking at by-pass filters and narrowed it down to the Spinner II or Cummins centriguard. Anybody have experience with either of these on an ISX without doing the oil shim fix for higher pressure? I have not installed a Spinner II yet, but I will when I've got some time at home. I have shimmed my oil pump, and run just over 40psi with Rotella and 1 gal of Sta-Lube. Long version of No I haven't on an ISX. I have however ran Spinner II's on all my previous Series 60's and like them very much. On my last S60, I used my gram/oz scale and measured and recorded the tare weight of the centrifugal cartridge, then when the time came to clean and replace the paper liner I'd weigh it dirty and subtract the tare to measure the actual weight of material removed by the Spinner. I bought that truck used with about 300k miles on it. I installed the Spinner before I put it to work. After four years/a little over 400k miles, the total sum of all material removed by the Spinner was just a few oz over 3 lbs! I'm like Rawze, I like measurable results, and I found an rough average of 3/4 of pound per 100k miles was about what it removed. Ymmv, but I am a believer in these things. I just recently shimmed my oil pump which is why I haven't yet installed it. Cummins stock oil pressure is not high enough to properly drive the centrifuge...the metal one that I have. I think 45-47 psi will drive it sufficiently. I've heard Spinner made one with a plastics centrifuge so the lower pressure will drive it, but I have no experience with that model. User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
