Peterbilt 587 starting
12-11-2023, (Subject: Peterbilt 587 starting )
RE: Peterbilt 587 starting
It seems like once it drops to 12.5v and less then it starts acting up
12-18-2023, (Subject: Peterbilt 587 starting )
(12-11-2023 )Samj Wrote:  It seems like once it drops to 12.5v and less then it starts acting up
Did you find the cause of your problem or are you still having an issue? Voltage-wise you really shouldn't have an issue cranking until the resting/non-cranking voltage drops below 12.1 or so and even then a resting voltage of about 11.8v or better should still turn it over while only sounding a bit sluggish (assuming you have the same 4 battery setup that my 2012 587 has).
 Thanks given by: hhow55
I'm thinking a bad starter.......
