| Isx leak |
| 07-20-2024, (Subject: Isx leak ) Post: #1 | |||
| Isx leak Got a cm870 04 built date. 860k miles. Leaking oil from bottom front section of engine. Don’t know if it’s crank seal or the front structure gasket. Leaking badly. Any suggestions? Picture down below is what it leaves at every stop I make sometimes worse. Thanks | |||
| 07-21-2024, (Subject: Isx leak ) Post: #2 | |||
| RE: Isx leak Could be anyone's guess. ... wipe everything down and find exactly where its coming from. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 09-01-2024, (Subject: Isx leak ) Post: #3 | |||
| RE: Isx leak Cleaned everything and change the crank seal, still leaking loosing a gallon a week messing up all over under the truck. Anyone knows quote or estimate to get front gear seal replaced? | |||
| 09-01-2024, (Subject: Isx leak ) Post: #4 | |||
| RE: Isx leak I would like to get it done at the Cummins shop in griffin that’s everyone recommendeds | |||
| 09-02-2024, (Subject: Isx leak ) Post: #5 | |||
RE: Isx leak (09-01-2024 )3406E Wrote: I would like to get it done at the Cummins shop in griffin that’s everyone recommendeds SO far, you have not shown a single pic of where the leak is originating from .. nor any detail .. so its anyone's guess. that place you mentioned would be ... Mr. Hag's shop - 'Haggai automotive' in griffin, GA. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 09-02-2024, (Subject: Isx leak ) Post: #6 | |||
| RE: Isx leak Will send better pictures when I go back underneath but it’s mostly leaking at the two front sides | |||
| 09-02-2024, (Subject: Isx leak ) Post: #7 | |||
| RE: Isx leak think the oil pan is leaking too, whoever did it put permatex on both sides of the gasket in the corners.all 4 corners is done like that | |||
| 09-02-2024, (Subject: Isx leak ) Post: #8 | |||
| RE: Isx leak Also found out awhile ago that it’s a after market oil pan made by some company called spectra premium on it, was always wondering why is my oil pan black | |||
| 09-02-2024, (Subject: Isx leak ) Post: #9 | |||
| RE: Isx leak Can also see it dripping from bolts | |||
