| X-15 derate warning |
| 01-09-2025, (Subject: X-15 derate warning ) Post: #1 | |||
| X-15 derate warning I just recently purchased a 2018 579 with X-15 truck has 710k mi, truck is drops about 10mph when pulling hills empty and is getting poor fuel mileage (5mpg) with light loads (15k) I also keep getting a warning for derate in 3hrs in which I let it go into a level 1 derate when it did this the truck didn’t lose power, how I cleared this warning was flip the key back and forth (7x) it’s not showing me any active code or faults. Truck is just lacking power, getting horrible MPG and throwing derate warnings, any advice will be greatly appreciated. | |||
| 01-09-2025, (Subject: X-15 derate warning ) Post: #2 | |||
| RE: X-15 derate warning There are so many different things it could be, I don't think anyone will really be able to help you without at least knowing what the codes are. I would highly recommend getting Cummins I N S I T E and a inline 6 adapter. I've had good luck with eBay and Amazon for those. That way you can tell us what codes you have. | |||
| 01-09-2025, (Subject: X-15 derate warning ) Post: #3 | |||
RE: X-15 derate warning (01-09-2025 )Tony Wrote: There are so many different things it could be, I don't think anyone will really be able to help you without at least knowing what the codes are. I would highly recommend getting Cummins I N S I T E and a inline 6 adapter. I've had good luck with eBay and Amazon for those. That way you can tell us what codes you have. I’m getting a code for low boost pressure | |||
| 01-09-2025, (Subject: X-15 derate warning ) Post: #4 | |||
| RE: X-15 derate warning What's the code number? There can be multiple codes related to low boost pressure | |||
| 01-09-2025, (Subject: X-15 derate warning ) Post: #5 | |||
| RE: X-15 derate warning start with a thorough egr tune-up. ref: http://rawze.com/forums/showthread.php?tid=842 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
