I have done the bubble test and ran the truck on one cylinder at a times and no luck. I jet a miss at idle here and there and under load I does the same. Any help I'm losing my mind over this.
let it sit overnight, pull the valve cover and crank it up. Look at it with a thermal camera and see what injector(s) are colder than the rest as it starts to warm up?
just some thoughts on it.
Don't have thermostat cam. Just thermogun may be that would work. Or just do old school and take exhaust manifold off and see witch on misses.
thermo gun will work check and see what you get right after start up.
I think maybe more along the line of actuators, how old are they?
(03-11-2017 )Mr Hagg Wrote: [ -> ]I think maybe more along the line of actuators, how old are they?
Good evening Mr. Hagg whats the name and number for your shop
So I did check for temp with thermo gun no big difference. So I took all off them out and one had half of the hole on the tip clogged. I had a spare one replaced it and everything is go. Sorry for late up date and than thanks for your help
