Is there any other way to check injectors
03-07-2017, (Subject: Is there any other way to check injectors )
I have done the bubble test and ran the truck on one cylinder at a times and no luck. I jet a miss at idle here and there and under load I does the same. Any help I'm losing my mind over this.
RE: Is there any other way to check injectors
let it sit overnight, pull the valve cover and crank it up. Look at it with a thermal camera and see what injector(s) are colder than the rest as it starts to warm up?
just some thoughts on it.
 Thanks given by: gatow900 , hhow55
Don't have thermostat cam. Just thermogun may be that would work. Or just do old school and take exhaust manifold off and see witch on misses.
03-11-2017, (Subject: Is there any other way to check injectors )
thermo gun will work check and see what you get right after start up.
 Thanks given by: scottydogtruck , gatow900
I think maybe more along the line of actuators, how old are they?
04-11-2017, (Subject: Is there any other way to check injectors )
(03-11-2017 )Mr Hagg Wrote:  I think maybe more along the line of actuators, how old are they?
Good evening Mr. Hagg whats the name and number for your shop
 Thanks given by: dunwitit
04-12-2017, (Subject: Is there any other way to check injectors )
So I did check for temp with thermo gun no big difference. So I took all off them out and one had half of the hole on the tip clogged. I had a spare one replaced it and everything is go. Sorry for late up date and than thanks for your help
 Thanks given by: Rawze , Hammerhead
